--- title: "Vibe connection guide" slug: "vibe-connection-guide" description: "Connect your Vibe data to Supermetrics with our guide on permissions, API keys, and detailed connection instructions for seamless reporting." updated: 2026-07-08T11:55:44Z published: 2026-07-08T11:55:44Z canonical: "docs.supermetrics.com/vibe-connection-guide" --- > ## Documentation Index > Fetch the complete documentation index at: https://docs.supermetrics.com/llms.txt > Use this file to discover all available pages before exploring further. # Vibe connection guide This guide contains all permissions and requirements for connecting your Vibe data to Supermetrics. You can connect to data sources from the [Data sources page on the Supermetrics Hub](https://hub.supermetrics.com/token-management). On the Hub, you can also [share an authentication link](https://docs.supermetrics.com/v1/docs/how-to-connect-to-data-sources-from-supermetrics-hub#share-authentication-link) to connect to a data source you don't have direct access to. After you connect to the data source on the Hub, you can use the data source connection in [all available destinations](/docs/vibe-connection-guide#connection-instructions). ## Required permissions Before using the Vibe connector, you need to create an API key on the Vibe platform. To create your API key: 1. In your [Vibe account](https://www.vibe.co/sign-in), navigate to **Settings** → **API Keys**. 2. Click **+ Create API key**. 3. Give a meaningful name for the key that helps you identify which integration it’s used for. 4. Once the key is created, copy and store it securely. Note that you’ll only be shown the full key once — after that, only a shortened reference will appear in your settings. ## Query types - **Campaign performance**: Pull all the dimensions and metrics for your CTV campaigns, for different timezones and attribution windows. ## Connection instructions When connecting to Vibe, you need to enter your API key and select the advertisers to use when prompted. 1. Select the Vibe data source [on the Supermetrics Hub](https://hub.supermetrics.com/token-management) or in the data destination. 2. Insert your API key for Vibe. 3. If prompted, choose to make this connection [shared or private](/v1/docs/about-shared-and-private-connections). 4. Click **Start**. 5. In your data destination, select the advertisers to include in your reporting, and a query type, if prompted. See detailed instructions on [how to connect to a data source from the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-connect-to-data-sources-from-supermetrics-hub). You can also connect to Vibe from these destinations: - Google Sheets: [How to connect to a Supermetrics data source in Google Sheets](https://docs.supermetrics.com/docs/how-to-connect-to-a-supermetrics-data-source-in-google-sheets) - Data Studio: [How to connect data sources to Data Studio](/v1/docs/how-to-connect-data-sources-to-data-studio) - Excel: [How to connect data sources to Excel with Supermetrics](https://docs.supermetrics.com/docs/how-to-connect-data-sources-to-excel-with-supermetrics) - Power BI: [How to create your first Supermetrics query for Power BI](https://docs.supermetrics.com/docs/how-to-create-your-first-supermetrics-query-for-power-bi) - The Supermetrics API: [How to use the Query Manager](https://docs.supermetrics.com/docs/how-to-use-the-query-manager) - Data warehouse and cloud storage (Hub): [How to create a transfer](https://docs.supermetrics.com/docs/how-to-create-a-transfer) - BigQuery (marketplace): [How to create a BigQuery (marketplace) transfer](https://docs.supermetrics.com/v1/docs/how-to-create-a-bigquery-marketplace-transfer) ## More resources - [How to reauthenticate a data source connection](/v1/docs/how-to-reauthenticate-a-data-source-connection) - [How to manage data source connections on the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-manage-data-source-connections-on-supermetrics-hub)
