--- title: "TikTok Organic connection guide" slug: "tiktok-organic-connection-guide" description: "Connect your TikTok Organic data to Supermetrics with our guide. Learn about permissions, query types, and connection instructions for effective reporting." updated: 2026-07-08T11:55:44Z published: 2026-07-08T11:55:44Z canonical: "docs.supermetrics.com/tiktok-organic-connection-guide" --- > ## Documentation Index > Fetch the complete documentation index at: https://docs.supermetrics.com/llms.txt > Use this file to discover all available pages before exploring further. # TikTok Organic connection guide This guide contains all permissions and requirements for connecting your TikTok Organic data to Supermetrics. You can connect to data sources from the [Data sources page on the Supermetrics Hub](https://hub.supermetrics.com/token-management). On the Hub, you can also [share an authentication link](https://docs.supermetrics.com/v1/docs/how-to-connect-to-data-sources-from-supermetrics-hub#share-authentication-link) to connect to a data source you don't have direct access to. After you connect to the data source on the Hub, you can use the data source connection in [all available destinations](/docs/tiktok-organic-connection-guide#connection-instructions). ## Required permissions To fetch data using the TikTok Organic data source connector, you need to connect to the data source using your TikTok Business or Personal account. Note that the personal account needs to have at least 100 followers, analytics enabled, and at least one public post to get data through the connector. You log in to Supermetrics TikTok Organic connector with the same credentials that are used for logging in to the TikTok profile on the TikTok mobile app. It is not possible to log in with your TikTok account to get data from other accounts, even if you have been granted the permissions on TikTok. ## Query types Query types define what sort of metrics and dimensions are available. You need to select one of the following query types when pulling data: - **Profile overview**: Get profile-level data on how many people started to follow you, viewed your profile, or viewed or engaged with your profile. Profile data is available for the last 60 days and can be broken down on a daily level. - **Video performance**: Get video-level data on how many people viewed your video, engaged with your video, or how long your videos were watched on average. Video data is available as lifetime value per video. This means the video performance data can't be broken down for a specific date range or by date. - **Followers by country**: Get a percentage distribution of your follower base by country. Followers by country data is available for the last 60 days. - **Followers by gender**: Get a percentage distribution of your follower base by gender. Followers by gender data is available for the last 60 days. ## Connection instructions When connecting to TikTok Organic, you need to log in to TikTok and select a query type when prompted. 1. Select the TikTok Organic data source [on the Supermetrics Hub](https://hub.supermetrics.com/token-management) or in the data destination. 2. If prompted, choose to make this connection [shared or private](/v1/docs/about-shared-and-private-connections). 3. Click **Start**. 4. Log in to the TikTok account you want to fetch data from. 5. Click **Authorize** to allow the Supermetrics app to access your profile data. 6. Click **Start**. 7. In your data destination, select the query type to use in your reporting. See detailed instructions on [how to connect to a data source from the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-connect-to-data-sources-from-supermetrics-hub). You can also connect to TikTok Organic from these destinations: - Google Sheets: [How to connect to a Supermetrics data source in Google Sheets](https://docs.supermetrics.com/docs/how-to-connect-to-a-supermetrics-data-source-in-google-sheets) - Data Studio: [How to connect data sources to Data Studio](/v1/docs/how-to-connect-data-sources-to-data-studio) - Excel: [How to connect data sources to Excel with Supermetrics](https://docs.supermetrics.com/docs/how-to-connect-data-sources-to-excel-with-supermetrics) - Power BI: [How to create your first Supermetrics query for Power BI](https://docs.supermetrics.com/docs/how-to-create-your-first-supermetrics-query-for-power-bi) - The Supermetrics API: [How to use the Query Manager](https://docs.supermetrics.com/docs/how-to-use-the-query-manager) - Data warehouse and cloud storage (Hub): [How to create a transfer](https://docs.supermetrics.com/docs/how-to-create-a-transfer) - BigQuery (marketplace): [How to create a BigQuery (marketplace) transfer](https://docs.supermetrics.com/v1/docs/how-to-create-a-bigquery-marketplace-transfer) ## More resources - [How to reauthenticate a data source connection](/v1/docs/how-to-reauthenticate-a-data-source-connection) - [How to manage data source connections on the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-manage-data-source-connections-on-supermetrics-hub)
