--- title: "Teads connection guide" slug: "teads-connection-guide" description: "Connect your Teads data to Supermetrics with our guide. Learn about API keys, permissions, and reporting for seamless data integration." updated: 2026-07-08T11:55:44Z published: 2026-07-08T11:55:44Z canonical: "docs.supermetrics.com/teads-connection-guide" --- > ## Documentation Index > Fetch the complete documentation index at: https://docs.supermetrics.com/llms.txt > Use this file to discover all available pages before exploring further. # Teads connection guide This guide contains all permissions and requirements for connecting your Teads data to Supermetrics. You can connect to data sources from the [Data sources page on the Supermetrics Hub](https://hub.supermetrics.com/token-management). On the Hub, you can also [share an authentication link](https://docs.supermetrics.com/v1/docs/how-to-connect-to-data-sources-from-supermetrics-hub#share-authentication-link) to connect to a data source you don't have direct access to. After you connect to the data source on the Hub, you can use the data source connection in [all available destinations](/docs/teads-connection-guide#connection-instructions). ## Required permissions To connect Supermetrics to your Teads account, you need to create an API key. ### Create an API key 1. [Log in to your Teads account](https://login.teads.tv/login). 2. Click the gear icon in the header to open the **Settings** screen. 3. Click **Generate API key** in the API keys section. 4. Click the edit icon to change the API key name. 5. Copy the API key shown under the name of the key. You need the key when connecting Teads to Supermetrics. ## Query types If prompted, you need to select a query type to pull data. - Reporting ## Connection instructions When connecting to Teads, you need to provide your API key and select the timezone when prompted. 1. Select the Teads data source [on the Supermetrics Hub](https://hub.supermetrics.com/token-management) or in the data destination. 2. Enter your API key. 3. Give your login a name to recognize the login later if you have multiple logins. 4. If prompted, choose to make this connection [shared or private](/v1/docs/about-shared-and-private-connections). 5. Click **Start**. 6. In your data destination, select the timezone. You may also be asked to select accounts to pull data from and a query type. See detailed instructions on [how to connect to a data source from the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-connect-to-data-sources-from-supermetrics-hub). You can also connect to Teads from these destinations: - Google Sheets: [How to connect to a Supermetrics data source in Google Sheets](https://docs.supermetrics.com/docs/how-to-connect-to-a-supermetrics-data-source-in-google-sheets) - Data Studio: [How to connect data sources to Data Studio](/v1/docs/how-to-connect-data-sources-to-data-studio) - Excel: [How to connect data sources to Excel with Supermetrics](https://docs.supermetrics.com/docs/how-to-connect-data-sources-to-excel-with-supermetrics) - Power BI: [How to create your first Supermetrics query for Power BI](https://docs.supermetrics.com/docs/how-to-create-your-first-supermetrics-query-for-power-bi) - The Supermetrics API: [How to use the Query Manager](https://docs.supermetrics.com/docs/how-to-use-the-query-manager) - Data warehouse and cloud storage (Hub): [How to create a transfer](https://docs.supermetrics.com/docs/how-to-create-a-transfer) - BigQuery (marketplace): [How to create a BigQuery (marketplace) transfer](https://docs.supermetrics.com/v1/docs/how-to-create-a-bigquery-marketplace-transfer) ## More resources - [How to reauthenticate a data source connection](/v1/docs/how-to-reauthenticate-a-data-source-connection) - [How to manage data source connections on the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-manage-data-source-connections-on-supermetrics-hub)
