--- title: "Shopee Ads connection guide" slug: "shopee-ads-connection-guide" description: "Connect your Shopee Ads data to Supermetrics with our guide. Learn about permissions, authentication, and query types for effective reporting." updated: 2026-07-08T11:55:44Z published: 2026-07-08T11:55:44Z canonical: "docs.supermetrics.com/shopee-ads-connection-guide" --- > ## Documentation Index > Fetch the complete documentation index at: https://docs.supermetrics.com/llms.txt > Use this file to discover all available pages before exploring further. # Shopee Ads connection guide This guide contains all permissions and requirements for connecting your Shopee Ads data to Supermetrics. You can connect to data sources from the [Data sources page on the Supermetrics Hub](https://hub.supermetrics.com/token-management). On the Hub, you can also [share an authentication link](https://docs.supermetrics.com/v1/docs/how-to-connect-to-data-sources-from-supermetrics-hub#share-authentication-link) to connect to a data source you don't have direct access to. After you connect to the data source on the Hub, you can use the data source connection in [all available destinations](/docs/shopee-ads-connection-guide#connection-instructions). ## Required permissions To pull commerce data from Shopee using Supermetrics, you need a Shopee account. In addition: - You must connect to Shopee using a normal Shop account that has access to a single shop per login. Main accounts and sub-accounts are not compatible with the connector. - You need the **email/phone number/user name** and **password** of the Shop account. Learn more about [different types of Shopee accounts](https://seller.shopee.com.my/edu/article/26762/multiple-shop-chat-management-on-sub-account-platform). ## Query types If prompted, you need to select a query type to pull data. - **CPC Ads**: Retrieve performance data for CPC ads. ## Connection instructions When connecting to Shopee Ads, you need to log in to Shopee Ads and select the shop region when prompted. 1. Select the Shopee Ads data source [on the Supermetrics Hub](https://hub.supermetrics.com/token-management) or in the data destination. 2. Select your store region from the dropdown. 3. If prompted, choose to make this connection [shared or private](/v1/docs/about-shared-and-private-connections). 4. Click **Start**. 5. Select your store region from the dropdown and insert your email/phone number/user name and password. 6. Confirm the authorization for Supermetrics to access your Shopee data. 7. In your data destination, select the stores to include in your reporting and a query type, if prompted. See detailed instructions on [how to connect to a data source from the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-connect-to-data-sources-from-supermetrics-hub). You can also connect to Shopee Ads from these destinations: - Google Sheets: [How to connect to a Supermetrics data source in Google Sheets](https://docs.supermetrics.com/docs/how-to-connect-to-a-supermetrics-data-source-in-google-sheets) - Data Studio: [How to connect data sources to Data Studio](/v1/docs/how-to-connect-data-sources-to-data-studio) - Excel: [How to connect data sources to Excel with Supermetrics](https://docs.supermetrics.com/docs/how-to-connect-data-sources-to-excel-with-supermetrics) - Power BI: [How to create your first Supermetrics query for Power BI](https://docs.supermetrics.com/docs/how-to-create-your-first-supermetrics-query-for-power-bi) - The Supermetrics API: [How to use the Query Manager](https://docs.supermetrics.com/docs/how-to-use-the-query-manager) - Data warehouse and cloud storage (Hub): [How to create a transfer](https://docs.supermetrics.com/docs/how-to-create-a-transfer) - BigQuery (marketplace): [How to create a BigQuery (marketplace) transfer](https://docs.supermetrics.com/v1/docs/how-to-create-a-bigquery-marketplace-transfer) ## More resources - [How to reauthenticate a data source connection](/v1/docs/how-to-reauthenticate-a-data-source-connection) - [How to manage data source connections on the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-manage-data-source-connections-on-supermetrics-hub)
