--- title: "Readpeak connection guide" slug: "readpeak-connection-guide" description: "Connect your Readpeak data to Supermetrics with our guide on permissions, API keys, and detailed connection instructions for various platforms." updated: 2026-07-08T11:55:02Z published: 2026-07-08T11:55:02Z canonical: "docs.supermetrics.com/readpeak-connection-guide" --- > ## Documentation Index > Fetch the complete documentation index at: https://docs.supermetrics.com/llms.txt > Use this file to discover all available pages before exploring further. # Readpeak connection guide This guide contains all permissions and requirements for connecting your Readpeak data to Supermetrics. You can connect to data sources from the [Data sources page on the Supermetrics Hub](https://hub.supermetrics.com/token-management). On the Hub, you can also [share an authentication link](https://docs.supermetrics.com/v1/docs/how-to-connect-to-data-sources-from-supermetrics-hub#share-authentication-link) to connect to a data source you don't have direct access to. After you connect to the data source on the Hub, you can use the data source connection in [all available destinations](/docs/readpeak-connection-guide#connection-instructions). ## Required permissions To connect to Readpeak, you need: - A Readpeak account with the **Administrator**, **Producer**, or **Manager** user role to connect - A copy of the account's API key ****Set your account role**** 1. Log in to Readpeak. 2. In the top right corner, click **Settings**. 3. Open the **Profile** tab. 4. Check your account's user role under **Role**. If you don't have the right permissions, get in touch with your administrator for help. ****Get your API key**** 1. [Log in to Readpeak's API manager](http://app.readpeak.com/reports/api). 2. Navigate to the top left corner. You'll find your key under **Your API Key**. Be sure to **keep your API key safe and secure**, as it gives access to all of your account's data. ## Query types If prompted, you need to select a query type to pull data. - **Campaigns report**: Fetches all the basic ad performance metrics for your ad campaigns ## Connection instructions When connecting to Readpeak, you need to provide your API key. 1. Select the Readpeak data source [on the Supermetrics Hub](https://hub.supermetrics.com/token-management) or in the data destination. 2. Enter your API key. 3. Give your login a name to recognize the login later if you have multiple logins. 4. If prompted, choose to make this connection [shared or private](/v1/docs/about-shared-and-private-connections). 5. Click **Start**. 6. In your data destination, select the accounts to pull data from and a query type, if prompted. See detailed instructions on [how to connect to a data source from the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-connect-to-data-sources-from-supermetrics-hub). You can also connect to Readpeak from these destinations: - Google Sheets: [How to connect to a Supermetrics data source in Google Sheets](https://docs.supermetrics.com/docs/how-to-connect-to-a-supermetrics-data-source-in-google-sheets) - Data Studio: [How to connect data sources to Data Studio](/v1/docs/how-to-connect-data-sources-to-data-studio) - Excel: [How to connect data sources to Excel with Supermetrics](https://docs.supermetrics.com/docs/how-to-connect-data-sources-to-excel-with-supermetrics) - Power BI: [How to create your first Supermetrics query for Power BI](https://docs.supermetrics.com/docs/how-to-create-your-first-supermetrics-query-for-power-bi) - The Supermetrics API: [How to use the Query Manager](https://docs.supermetrics.com/docs/how-to-use-the-query-manager) - Data warehouse and cloud storage (Hub): [How to create a transfer](https://docs.supermetrics.com/docs/how-to-create-a-transfer) - BigQuery (marketplace): [How to create a BigQuery (marketplace) transfer](https://docs.supermetrics.com/v1/docs/how-to-create-a-bigquery-marketplace-transfer) ## More resources - [How to reauthenticate a data source connection](/v1/docs/how-to-reauthenticate-a-data-source-connection) - [How to manage data source connections on the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-manage-data-source-connections-on-supermetrics-hub)
