--- title: "Prisjakt connection guide" slug: "prisjakt-connection-guide" description: "Connect your Prisjakt data to Supermetrics with our guide. Learn about permissions, client ID, and query types for seamless data integration." updated: 2026-07-08T11:55:02Z published: 2026-07-08T11:55:02Z canonical: "docs.supermetrics.com/prisjakt-connection-guide" --- > ## Documentation Index > Fetch the complete documentation index at: https://docs.supermetrics.com/llms.txt > Use this file to discover all available pages before exploring further. # Prisjakt connection guide This guide contains all permissions and requirements for connecting your Prisjakt data to Supermetrics. You can connect to data sources from the [Data sources page on the Supermetrics Hub](https://hub.supermetrics.com/token-management). On the Hub, you can also [share an authentication link](https://docs.supermetrics.com/v1/docs/how-to-connect-to-data-sources-from-supermetrics-hub#share-authentication-link) to connect to a data source you don't have direct access to. After you connect to the data source on the Hub, you can use the data source connection in [all available destinations](/docs/prisjakt-connection-guide#connection-instructions). ## Required permissions With Prisjakt, you can fetch data from the following price comparison websites: - Prisjakt (Sweden, Norway) - Prisjagt (Denmark) - PriceSpy (UK, New Zealand) - leDénicheur (France) - Hintaopas (Finland) Before using the Prisjakt connector, you need a client ID and client secret. To get your client ID and client secret, reach out to your Prisjakt contact person. There is no self-service option at the moment. Please note that each client ID and client secret has access to specific shops in Prisjakt. Make sure that your client ID and client secret have permissions to all relevant shops you want to use in Supermetrics. ## Query types If prompted, you need to select a query type to pull data. - **Product performance**: Pull a month-level report of the dimensions and metrics. ## Connection instructions When connecting to Prisjakt, you need to provide your client ID and client secret. 1. Select the Prisjakt data source [on the Supermetrics Hub](https://hub.supermetrics.com/token-management) or in the data destination. 2. If prompted, choose to make this connection [shared or private](/v1/docs/about-shared-and-private-connections). 3. Enter the client ID and client secret. 4. Give your account a name. The name can be anything — its purpose is for you to recognize the account later in case you have multiple logins. 5. Click **Start**. 6. In your data destination, select the accounts to pull data from and a query type, if prompted. See detailed instructions on [how to connect to a data source from the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-connect-to-data-sources-from-supermetrics-hub). You can also connect to Prisjakt from these destinations: - Google Sheets: [How to connect to a Supermetrics data source in Google Sheets](https://docs.supermetrics.com/docs/how-to-connect-to-a-supermetrics-data-source-in-google-sheets) - Data Studio: [How to connect data sources to Data Studio](/v1/docs/how-to-connect-data-sources-to-data-studio) - Excel: [How to connect data sources to Excel with Supermetrics](https://docs.supermetrics.com/docs/how-to-connect-data-sources-to-excel-with-supermetrics) - Power BI: [How to create your first Supermetrics query for Power BI](https://docs.supermetrics.com/docs/how-to-create-your-first-supermetrics-query-for-power-bi) - The Supermetrics API: [How to use the Query Manager](https://docs.supermetrics.com/docs/how-to-use-the-query-manager) - Data warehouse and cloud storage (Hub): [How to create a transfer](https://docs.supermetrics.com/docs/how-to-create-a-transfer) - BigQuery (marketplace): [How to create a BigQuery (marketplace) transfer](https://docs.supermetrics.com/v1/docs/how-to-create-a-bigquery-marketplace-transfer) ## More resources - [How to reauthenticate a data source connection](/v1/docs/how-to-reauthenticate-a-data-source-connection) - [How to manage data source connections on the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-manage-data-source-connections-on-supermetrics-hub)
