--- title: "Plausible connection guide" slug: "plausible-connection-guide" description: "Connect your Plausible data to Supermetrics with our guide. Learn about permissions, query types, and connection instructions for seamless integration." updated: 2026-07-08T11:55:02Z published: 2026-07-08T11:55:02Z canonical: "docs.supermetrics.com/plausible-connection-guide" stale: true --- > ## Documentation Index > Fetch the complete documentation index at: https://docs.supermetrics.com/llms.txt > Use this file to discover all available pages before exploring further. # Plausible connection guide This guide contains all permissions and requirements for connecting your Plausible data to Supermetrics. You can connect to data sources from the [Data sources page on the Supermetrics Hub](https://hub.supermetrics.com/token-management). On the Hub, you can also [share an authentication link](https://docs.supermetrics.com/v1/docs/how-to-connect-to-data-sources-from-supermetrics-hub#share-authentication-link) to connect to a data source you don't have direct access to. After you connect to the data source on the Hub, you can use the data source connection in [all available destinations](/docs/plausible-connection-guide#connection-instructions). ## Before you begin Before using the Plausible connector, you’ll need to generate an **API key** for your plausible account. ### How to create an API Key 1. Log in to your Plausible account. 2. Open the [API keys page](https://plausible.io/settings/api-keys). 3. Click **New API Key** to generate a new API key. You can use either the **Stats API** or **Sites API** key type. 4. The API Key will be shown only once. Copy it to a secure location for later use. ## Query types If prompted, you need to select a query type to pull data. - **Stats:** View historical and real-time stats for your website. ## Connection instructions When connecting to Plausible, you need to enter your API Key and select the query type if prompted. 1. Select the Plausible data source [on the Supermetrics Hub](https://hub.supermetrics.com/token-management) or in the data destination. 2. Enter your Plausible **API Key** and give a name for your login. 3. If prompted, choose to make this connection [shared or private](/v1/docs/about-shared-and-private-connections). 4. Click **Start**. 5. In your data destination, select the account to pull data from and a query type, prompted. See detailed instructions on [how to connect to a data source from the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-connect-to-data-sources-from-supermetrics-hub). You can also connect to Plausible from these destinations: - Google Sheets: [How to connect to a Supermetrics data source in Google Sheets](https://docs.supermetrics.com/docs/how-to-connect-to-a-supermetrics-data-source-in-google-sheets) - Data Studio: [How to connect data sources to Data Studio](/v1/docs/how-to-connect-data-sources-to-data-studio) - Excel: [How to connect data sources to Excel with Supermetrics](https://docs.supermetrics.com/docs/how-to-connect-data-sources-to-excel-with-supermetrics) - Power BI: [How to create your first Supermetrics query for Power BI](https://docs.supermetrics.com/docs/how-to-create-your-first-supermetrics-query-for-power-bi) - The Supermetrics API: [How to use the Query Manager](https://docs.supermetrics.com/docs/how-to-use-the-query-manager) - Data warehouse and cloud storage (Hub): [How to create a transfer](https://docs.supermetrics.com/docs/how-to-create-a-transfer) - BigQuery (marketplace): [How to create a BigQuery (marketplace) transfer](https://docs.supermetrics.com/v1/docs/how-to-create-a-bigquery-marketplace-transfer) ## More resources - [How to reauthenticate a data source connection](/v1/docs/how-to-reauthenticate-a-data-source-connection) - [How to manage data source connections on the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-manage-data-source-connections-on-supermetrics-hub)
