--- title: "Mixpanel connection guide" slug: "mixpanel-connection-guide" description: "Connect your Mixpanel data to Supermetrics with our guide on permissions, service accounts, and data residency for seamless data integration." tags: ["Analytics", "Mobile"] updated: 2026-07-08T09:01:07Z published: 2026-07-08T09:01:07Z canonical: "docs.supermetrics.com/mixpanel-connection-guide" --- > ## Documentation Index > Fetch the complete documentation index at: https://docs.supermetrics.com/llms.txt > Use this file to discover all available pages before exploring further. # Mixpanel connection guide This guide contains all permissions and requirements for connecting your Mixpanel data to Supermetrics. You can connect to data sources from the [Data sources page on the Supermetrics Hub](https://hub.supermetrics.com/token-management). On the Hub, you can also [share an authentication link](https://docs.supermetrics.com/v1/docs/how-to-connect-to-data-sources-from-supermetrics-hub#share-authentication-link) to connect to a data source you don't have direct access to. After you connect to the data source on the Hub, you can use the data source connection in [all available destinations](/docs/mixpanel-connection-guide#connection-instructions). ## Required permissions A Mixpanel service account is required to query the data in Supermetrics, and you must identify which Data Residency your Mixpanel project uses. ### How to find your project’s Data Residency 1. Log in to your [Mixpanel dashboard](https://mixpanel.com/project/). 2. In the bottom left corner, click the cogwheel icon. Hover over **Settings** and select **Project settings**. 3. In the **Project Details** table, the Data Residency will be visible. ### How to create a service account 1. Log in to your [Mixpanel dashboard](https://mixpanel.com/project/). 2. In the bottom left corner, click the cogwheel icon. Hover over **Settings** and select **Project settings**. 3. Select **Service accounts** from the navigation menu on the left side. 4. In the top right corner, click **Add service account**. 5. Enter a name for your new service account, for example “Supermetrics”. 6. Select **Consumer** as the project role. 7. Click **Add**. 8. Copy the **Service account name** and **Service account secret** to a secure location. [Learn more about service accounts in Mixpanel’s documentation.](https://developer.mixpanel.com/reference/service-accounts) ## Query types If prompted, you need to select a query type to pull data. - **Events**: Get event data to track interactions between a user and your product. ## Connection instructions When connecting to Mixpanel, you need to provide your account name and secret and select the data residency to use. 1. Select the Mixpanel data source [on the Supermetrics Hub](https://hub.supermetrics.com/token-management) or in the data destination. 2. Select the Data residency of your Mixpanel Project. 3. Enter your Mixpanel service account name and secret. 4. Give your login a name to recognize the login later in case you have multiple logins. 5. If prompted, choose to make this connection [shared or private](/v1/docs/about-shared-and-private-connections). 6. Click **Start**. 7. In your data destination, select the data residency and a query type to use in your report, if prompted. See detailed instructions on [how to connect to a data source from the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-connect-to-data-sources-from-supermetrics-hub). You can also connect to Mixpanel from these destinations: - Google Sheets: [How to connect to a Supermetrics data source in Google Sheets](https://docs.supermetrics.com/docs/how-to-connect-to-a-supermetrics-data-source-in-google-sheets) - Data Studio: [How to connect data sources to Data Studio](/v1/docs/how-to-connect-data-sources-to-data-studio) - Excel: [How to connect data sources to Excel with Supermetrics](https://docs.supermetrics.com/docs/how-to-connect-data-sources-to-excel-with-supermetrics) - Power BI: [How to create your first Supermetrics query for Power BI](https://docs.supermetrics.com/docs/how-to-create-your-first-supermetrics-query-for-power-bi) - The Supermetrics API: [How to use the Query Manager](https://docs.supermetrics.com/docs/how-to-use-the-query-manager) - Data warehouse and cloud storage (Hub): [How to create a transfer](https://docs.supermetrics.com/docs/how-to-create-a-transfer) - BigQuery (marketplace): [How to create a BigQuery (marketplace) transfer](https://docs.supermetrics.com/v1/docs/how-to-create-a-bigquery-marketplace-transfer) ## More resources - [How to reauthenticate a data source connection](/v1/docs/how-to-reauthenticate-a-data-source-connection) - [How to manage data source connections on the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-manage-data-source-connections-on-supermetrics-hub)
