--- title: "Meltwater connection guide" slug: "meltwater-connection-guide" description: "Connect your Meltwater data to Supermetrics with our guide on permissions, API tokens, and detailed connection instructions for seamless data integration." updated: 2026-07-08T09:01:07Z published: 2026-07-08T09:01:07Z canonical: "docs.supermetrics.com/meltwater-connection-guide" --- > ## Documentation Index > Fetch the complete documentation index at: https://docs.supermetrics.com/llms.txt > Use this file to discover all available pages before exploring further. # Meltwater connection guide This guide contains all permissions and requirements for connecting your Meltwater data to Supermetrics. You can connect to data sources from the [Data sources page on the Supermetrics Hub](https://hub.supermetrics.com/token-management). On the Hub, you can also [share an authentication link](https://docs.supermetrics.com/v1/docs/how-to-connect-to-data-sources-from-supermetrics-hub#share-authentication-link) to connect to a data source you don't have direct access to. After you connect to the data source on the Hub, you can use the data source connection in [all available destinations](/docs/meltwater-connection-guide#connection-instructions). ## Required permissions To use this connector, you need: - Access to the Meltwater API as part of your Meltwater subscription - A Meltwater API token You can create and get your API token by following these steps: 1. In Meltwater, go to **Account** → **Meltwater API** in the left-hand navigation. 2. If you do not have an existing API token, click **Generate API token**. Meltwater states that you can only have one API token at any time. 3. After you have generated the API token, you can enter a name for it. 4. Remember to copy the API token and store it securely since it is not possible to access the token in the future. [Learn more about Meltwater API credentials in Meltwater's documentation](https://developer.meltwater.com/guides/getting-started/api-credentials/). ## Query types If prompted, you need to select a query type to pull data. - **Export media**: Pull social listening data from your saved Searches in Meltwater. ## Connection instructions When connecting to Meltwater, you need to provide your API token. 1. Select the Meltwater data source [on the Supermetrics Hub](https://hub.supermetrics.com/token-management) or in the data destination. 2. Insert your API token. 3. Give a name for your login. 4. If prompted, choose to make this connection [shared or private](/v1/docs/about-shared-and-private-connections). 5. Click **Start**. 6. In your data destination, select the saved searches to use. See detailed instructions on [how to connect to a data source from the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-connect-to-data-sources-from-supermetrics-hub). You can also connect to Meltwater from these destinations: - The Supermetrics API: [How to use the Query Manager](https://docs.supermetrics.com/docs/how-to-use-the-query-manager) - Data warehouse and cloud storage (Hub): [How to create a transfer](https://docs.supermetrics.com/docs/how-to-create-a-transfer) - BigQuery (marketplace): [How to create a BigQuery (marketplace) transfer](https://docs.supermetrics.com/v1/docs/how-to-create-a-bigquery-marketplace-transfer) ## More resources - [How to reauthenticate a data source connection](/v1/docs/how-to-reauthenticate-a-data-source-connection) - [How to manage data source connections on the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-manage-data-source-connections-on-supermetrics-hub)
