--- title: "LinkedIn Ads connection guide" slug: "linkedin-ads-connection-guide" description: "Connect your LinkedIn data to Supermetrics with our guide on permissions, and connection instructions for seamless data integration." updated: 2026-07-08T09:01:07Z published: 2026-07-08T09:01:07Z canonical: "docs.supermetrics.com/linkedin-ads-connection-guide" --- > ## Documentation Index > Fetch the complete documentation index at: https://docs.supermetrics.com/llms.txt > Use this file to discover all available pages before exploring further. # LinkedIn Ads connection guide This guide contains all permissions and requirements for connecting your LinkedIn Ads data to Supermetrics. You can connect to data sources from the [Data sources page on the Supermetrics Hub](https://hub.supermetrics.com/token-management). On the Hub, you can also [share an authentication link](https://docs.supermetrics.com/v1/docs/how-to-connect-to-data-sources-from-supermetrics-hub#share-authentication-link) to connect to a data source you don't have direct access to. After you connect to the data source on the Hub, you can use the data source connection in [all available destinations](/docs/linkedin-ads-connection-guide#connection-instructions). ## Required permissions To connect to LinkedIn Ads, you need: - A LinkedIn account with at least **Viewer** access to an ad account. [Learn how to grant access to LinkedIn accounts](https://www.linkedin.com/help/linkedin/answer/5753/adding-editing-and-removing-user-permissions-on-advertising-accounts?lang=en). - **Admin** access to the Company Page is required for creative-level (ad content and metadata) granularity. ## Connection instructions When connecting to LinkedIn Ads, you need to log in to LinkedIn and select the accounts to use when prompted. 1. Select the LinkedIn Ads data source [on the Supermetrics Hub](https://hub.supermetrics.com/token-management) or in the data destination. 2. If prompted, choose to make this connection [shared or private](/v1/docs/about-shared-and-private-connections). 3. Click **Start**. 4. Enter your credentials and click **Sign in**. 5. In your data destination, select the accounts to pull data from. See detailed instructions on [how to connect to a data source from the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-connect-to-data-sources-from-supermetrics-hub). You can also connect to LinkedIn Ads from these destinations: - Google Sheets: [How to connect to a Supermetrics data source in Google Sheets](https://docs.supermetrics.com/docs/how-to-connect-to-a-supermetrics-data-source-in-google-sheets) - Data Studio: [How to connect data sources to Data Studio](/v1/docs/how-to-connect-data-sources-to-data-studio) - Excel: [How to connect data sources to Excel with Supermetrics](https://docs.supermetrics.com/docs/how-to-connect-data-sources-to-excel-with-supermetrics) - Power BI: [How to create your first Supermetrics query for Power BI](https://docs.supermetrics.com/docs/how-to-create-your-first-supermetrics-query-for-power-bi) - The Supermetrics API: [How to use the Query Manager](https://docs.supermetrics.com/docs/how-to-use-the-query-manager) - Data warehouse and cloud storage (Hub): [How to create a transfer](https://docs.supermetrics.com/docs/how-to-create-a-transfer) - BigQuery (marketplace): [How to create a BigQuery (marketplace) transfer](https://docs.supermetrics.com/v1/docs/how-to-create-a-bigquery-marketplace-transfer) ## More resources - [LinkedIn Ads report building guide](/v1/docs/linkedin-ads-report-building-guide) - [LinkedIn Ads support articles](/v1/docs/linkedin-ads) - [What to do if accounts, custom fields, or segments are missing from your report](/v1/docs/what-to-do-if-accounts-custom-fields-or-segments-are-missing-from-your-report) - [How to reauthenticate a data source connection](/v1/docs/how-to-reauthenticate-a-data-source-connection) - [How to manage data source connections on the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-manage-data-source-connections-on-supermetrics-hub)
