--- title: "LINE Ads connection guide" slug: "line-ads-connection-guide" description: "Connect your LINE Ads data to Supermetrics with our guide. Learn about permissions, API access, and query types for seamless data integration." updated: 2026-07-08T09:01:07Z published: 2026-07-08T09:01:07Z canonical: "docs.supermetrics.com/line-ads-connection-guide" --- > ## Documentation Index > Fetch the complete documentation index at: https://docs.supermetrics.com/llms.txt > Use this file to discover all available pages before exploring further. # LINE Ads connection guide This guide contains all permissions and requirements for connecting your LINE Ads data to Supermetrics. You can connect to data sources from the [Data sources page on the Supermetrics Hub](https://hub.supermetrics.com/token-management). On the Hub, you can also [share an authentication link](https://docs.supermetrics.com/v1/docs/how-to-connect-to-data-sources-from-supermetrics-hub#share-authentication-link) to connect to a data source you don't have direct access to. After you connect to the data source on the Hub, you can use the data source connection in [all available destinations](/docs/line-ads-connection-guide#connection-instructions). ## Required permissions Before using the LINE Ads data source connector, API access must be enabled for the relevant Group on your LINE Ads account. Please contact your LINE account manager to enable this. Once API access is enabled, you need a copy of the group ID, access key, and secret key of the group you want to connect to. ****Get your group ID**** 1. Log in to the [LINE Ad Manager](https://admanager.line.biz/group/). 2. Navigate to the **Groups** page. 3. The group ID is shown in the table next to the group name, in the format “G123456789”. ****Get your access key and secret key**** 1. Log in to the [LINE Ad Manager](https://admanager.line.biz/group/). 2. Navigate to the **Groups** page. 3. Select the group you want to fetch data for. 4. Click **Menu** in the top left corner. 5. Under **Settings**, click **Group settings**. 6. Copy the API access key and API secret key to a safe place. If you cannot see the secret key, click **Regenerate your API secret key**. ## Query types If prompted, you need to select a query type to pull data. - **Campaign performance**: Get aggregated performance data on campaign, ad group and ad level. ## Connection instructions When connecting to LINE Ads, you need to provide your LINE Ads credentials. 1. Select the LINE Ads data source [on the Supermetrics Hub](https://hub.supermetrics.com/token-management) or in the data destination. 2. If prompted, choose to make this connection [shared or private](/v1/docs/about-shared-and-private-connections). 3. Enter your group ID, access key, and secret key. 4. Give your login a name so that you can recognize the login later if you have multiple logins. 5. Click **Start**. 6. In your data destination, select a query type, if prompted. See detailed instructions on [how to connect to a data source from the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-connect-to-data-sources-from-supermetrics-hub). You can also connect to LINE Ads from these destinations: - Google Sheets: [How to connect to a Supermetrics data source in Google Sheets](https://docs.supermetrics.com/docs/how-to-connect-to-a-supermetrics-data-source-in-google-sheets) - Data Studio: [How to connect data sources to Data Studio](/v1/docs/how-to-connect-data-sources-to-data-studio) - Excel: [How to connect data sources to Excel with Supermetrics](https://docs.supermetrics.com/docs/how-to-connect-data-sources-to-excel-with-supermetrics) - Power BI: [How to create your first Supermetrics query for Power BI](https://docs.supermetrics.com/docs/how-to-create-your-first-supermetrics-query-for-power-bi) - The Supermetrics API: [How to use the Query Manager](https://docs.supermetrics.com/docs/how-to-use-the-query-manager) - Data warehouse and cloud storage (Hub): [How to create a transfer](https://docs.supermetrics.com/docs/how-to-create-a-transfer) - BigQuery (marketplace): [How to create a BigQuery (marketplace) transfer](https://docs.supermetrics.com/v1/docs/how-to-create-a-bigquery-marketplace-transfer) ## More resources - [How to reauthenticate a data source connection](/v1/docs/how-to-reauthenticate-a-data-source-connection) - [How to manage data source connections on the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-manage-data-source-connections-on-supermetrics-hub)
