--- title: "Integral Ad Science connection guide" slug: "integral-ad-science-connection-guide" description: "Connect your Integral Ad Science data to Supermetrics. Learn about permissions, query types, and connection instructions for seamless integration." updated: 2026-07-08T09:01:07Z published: 2026-07-08T09:01:07Z canonical: "docs.supermetrics.com/integral-ad-science-connection-guide" --- > ## Documentation Index > Fetch the complete documentation index at: https://docs.supermetrics.com/llms.txt > Use this file to discover all available pages before exploring further. # Integral Ad Science connection guide This guide contains all permissions and requirements for connecting your Integral Ad Science data to Supermetrics. You can connect to data sources from the [Data sources page on the Supermetrics Hub](https://hub.supermetrics.com/token-management). On the Hub, you can also [share an authentication link](https://docs.supermetrics.com/v1/docs/how-to-connect-to-data-sources-from-supermetrics-hub#share-authentication-link) to connect to a data source you don't have direct access to. After you connect to the data source on the Hub, you can use the data source connection in [all available destinations](/docs/integral-ad-science-connection-guide#connection-instructions). ## Required permissions To connect Supermetrics to your Integral Ad Science account, you need the username and password of your Integral Ad Science account. ## Query types If prompted, you need to select a query type to pull data. - **Performance**: Report performance of your ad campaigns on campaign, advertiser, team, placement, device or app level. ## Connection instructions When connecting to Integral Ad Science, you need to enter your IAS username and password and select the ias team to use when prompted. 1. Select the Integral Ad Science data source [on the Supermetrics Hub](https://hub.supermetrics.com/token-management) or in the data destination. 2. Enter your Integral Ad Science username and password. 3. If prompted, choose to make this connection [shared or private](/v1/docs/about-shared-and-private-connections). 4. Click **Start**. 5. In your data destination, select an IAS team to use in your report and a query type, if prompted. See detailed instructions on [how to connect to a data source from the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-connect-to-data-sources-from-supermetrics-hub). You can also connect to Integral Ad Science from these destinations: - Google Sheets: [How to connect to a Supermetrics data source in Google Sheets](https://docs.supermetrics.com/docs/how-to-connect-to-a-supermetrics-data-source-in-google-sheets) - Data Studio: [How to connect data sources to Data Studio](/v1/docs/how-to-connect-data-sources-to-data-studio) - Excel: [How to connect data sources to Excel with Supermetrics](https://docs.supermetrics.com/docs/how-to-connect-data-sources-to-excel-with-supermetrics) - Power BI: [How to create your first Supermetrics query for Power BI](https://docs.supermetrics.com/docs/how-to-create-your-first-supermetrics-query-for-power-bi) - The Supermetrics API: [How to use the Query Manager](https://docs.supermetrics.com/docs/how-to-use-the-query-manager) - Data warehouse and cloud storage (Hub): [How to create a transfer](https://docs.supermetrics.com/docs/how-to-create-a-transfer) - Data warehouse and cloud storage (Hub): [How to create a transfer](https://docs.supermetrics.com/docs/how-to-create-a-transfer) ## More resources - [How to reauthenticate a data source connection](/v1/docs/how-to-reauthenticate-a-data-source-connection) - [How to manage data source connections on the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-manage-data-source-connections-on-supermetrics-hub)
