--- title: "How to manage ad campaigns in Supermetrics Studio" slug: "how-to-manage-ad-campaigns-in-supermetrics-studio" description: "Learn how to review, pause, and adjust ad campaign budgets directly from a Supermetrics Studio dashboard." updated: 2026-10-30T07:14:49Z published: 2026-10-30T07:14:49Z canonical: "docs.supermetrics.com/how-to-manage-ad-campaigns-in-supermetrics-studio" --- > ## Documentation Index > Fetch the complete documentation index at: https://docs.supermetrics.com/llms.txt > Use this file to discover all available pages before exploring further. # How to manage ad campaigns in Supermetrics Studio With Supermetrics Studio, your dashboards can go beyond reporting. You can review your ad campaigns, pause them, and adjust their budgets directly from the dashboard, and the change applies on the ad platform itself. Campaign management is especially useful if you manage budgets and campaigns across platforms and want one place to act on your data, not just report on it. This article covers how to add campaign management to a dashboard, grant it the access it needs, and review changes before they go live. Campaign management in Supermetrics Studio uses the same write connections as campaign management in AI chats like Claude and ChatGPT. If you manage campaigns through a chat instead of a Supermetrics Studio dashboard, see [How to manage ad campaigns with AI tools](/v1/docs/how-to-manage-ad-campaigns-with-ai-tools). > [!NOTE] > Note on availability > > The campaign management feature and Supermetrics Studio are in early access. Currently, you can manage campaigns in Facebook Ads, Google Ads, TikTok Ads, LinkedIn Ads, Microsoft Advertising, ChatGPT Ads, and Snapchat Marketing. ## Before you begin Make sure you have the following in place before starting to manage your ad campaigns: - You have an active Supermetrics subscription with Supermetrics Studio as a destination. - You have connected to a data source account with at least 1 of the supported ad platforms: Google Ads, Meta Ads, Microsoft Advertising, TikTok Ads, ChatGPT Ads, LinkedIn Ads, or Snapchat Marketing. See [our connection guidance for details on how to connect to these data sources](/v1/docs/connect). - You need to grant campaign write access to the accounts you want to manage. You can only grant write access to accounts that belong to data source connections you own. ### Grant write access to your ad accounts Before you can create or update campaigns from a dashboard, grant campaign write access to the accounts you want to manage. 1. Go to [Campaign write access on the Supermetrics Hub](https://hub.supermetrics.com/write-settings). 2. Select the accounts you want to use for campaign management. 3. Select when human approval is needed. Options for human approval: - **No human approval**: Changes apply immediately. - **Going live**: Approve before a campaign goes live, including unpausing one. - **Budget + going live**: Approve before budget changes on live campaigns and before a campaign goes live. - **All live changes**: Approve any change to a live campaign (including enabling the campaign). 4. Click **Save**. Once write access is granted, you can manage campaigns from a dashboard in Supermetrics Studio. Every change is logged in the [Campaign change history](https://hub.supermetrics.com/campaign-history) on the Supermetrics Hub, so you can see exactly what was changed. In the **Edit** view in Supermetrics Studio, you can ask SuperAI to undo actions if needed. ## Instructions ### Add campaign management to a Supermetrics Studio dashboard 1. Open [Supermetrics Studio](https://studio.supermetrics.com). 2. Open a dashboard where you want to manage campaigns, or create a new dashboard and connect the ad platform data you want to work with. 3. In the chat window, describe the campaign management view you want to add to the dashboard. For example, ask for a view that lets you review your campaigns and adjust their budgets or status. Example prompt: - `Add a tab to this dashboard called 'Campaign Management and Planning.' Provide a concise overview of all campaigns, alongside action buttons that can be used to adjust budgets, pause campaigns, and adjust campaign strategies. Ensure no change to a campaign can be made until confirmation from the user takes place.` 4. Supermetrics Studio adds the campaign management view to your dashboard. The view shows your current campaigns alongside the changes you can make, such as pausing a campaign or adjusting its budget. If a feature, such as a Pause button, is missing, just ask SuperAI to add it to the dashboard. ### Adjust campaign budgets 1. Go to the Supermetrics Studio dashboard where campaign management is enabled. 2. Click the buttons to adjust the budget — this depends on the user interface you set up in Supermetrics Studio. 3. Review the change when Supermetrics Studio asks you to confirm it. The exact campaign and the change are shown before anything is applied, and nothing changes until you confirm it. If you see an error stating that the budget change is too big, split the change to smaller steps. To see what changed, open [Campaign change history on the Supermetrics Hub](https://hub.supermetrics.com/campaign-history). Every change is logged with its old and new values. In the **Edit** view in Supermetrics Studio, you can ask SuperAI to reset the campaign to a previous value, if needed. > [!WARNING] > Note > > Always double-check a campaign change and its cost impact before you confirm it. You're responsible for the actions taken in your ad accounts and any related cost. ## Troubleshooting ### Write access isn't working even though it's enabled In Supermetrics Studio, you’re logged in to one Supermetrics team at a time. Campaign write access is enabled on the Supermetrics Hub separately for each team. Make sure that you’re logged in to Studio with the same team the campaign write access was enabled for. If campaign changes fail with `WRITE_ACCESS_NOT_ENABLED` error, try the following steps. #### Enable write access in the right team 1. [Log in to the Supermetrics Hub](https://hub.supermetrics.com) with the same email you used to connect to Supermetrics Studio. 2. Open the link in the error. The link takes you to the **Campaign write access** page on the Supermetrics Hub in the team you’re using. 3. Enable write access for the ad account and click **Save**. 4. Try make the change again in Supermetrics Studio. You don't need to reconnect. Did you switch write access on with a different email? Each email is a separate login with its own team. Write access enabled under another email doesn't apply here. > [!NOTE] > Ad account not on the list or can’t change settings? > > Only the person who connected the ad account to Supermetrics can enable write access for it. Ask the person who owns the connection to enable write access. #### Switch to the right team in Supermetrics Studio If you notice that you’re not using the right team in Supermetrics Studio, log out of Supermetrics Studio and log back in with the right team. For a team under a different email address, connect with that email. #### Check your access in the ad platform Write access in Supermetrics doesn't change your role in the ad platform. If you have view-only access to the Google Ads or Meta account, campaign changes will still fail. Ask the account admin for edit access. ### Campaign management support by data source Campaign management is under active development. The following list reflects current gaps rather than permanent restrictions. - **Google Ads**: Life Events aren't supported. - **Google Ads**: When you add keywords, check the notes in the response. If a keyword wasn't added, the note tells you why. You can also confirm new keywords in Google Ads. We recommend reviewing changes in the data source reporting directly. ## More resources - [Supermetrics Studio](/v1/docs/supermetrics-studio) - [How to manage ad campaigns with AI tools](/v1/docs/how-to-manage-ad-campaigns-with-ai-tools) - [Supermetrics MCP server](/v1/docs/supermetrics-mcp-server) - [About Business Context in AI tools and Supermetrics Studio](/v1/docs/about-business-context-in-ai-tools-and-supermetrics-studio)
