--- title: "How to fix missing Instagram accounts" slug: "how-to-fix-missing-instagram-accounts" description: "Troubleshoot missing Instagram accounts in Supermetrics by checking permissions, refreshing connections, and verifying Facebook Page claims." updated: 2026-10-15T13:28:27Z published: 2026-10-15T13:28:27Z canonical: "docs.supermetrics.com/how-to-fix-missing-instagram-accounts" --- > ## Documentation Index > Fetch the complete documentation index at: https://docs.supermetrics.com/llms.txt > Use this file to discover all available pages before exploring further. # How to fix missing Instagram accounts Follow these steps to find any Instagram account that doesn't show in Supermetrics and add it to your reports. ## Instructions ****Check your permissions**** If you make changes to your Instagram account's permissions scope, or if Supermetrics loses the permissions it needs to connect to the account, check your Instagram account's settings. Make sure it has [the permissions Supermetrics needs](/v1/docs/instagram-insights-permissions-guide) to pull its data. ****Refresh and reset your connection**** If your permissions are right but the accounts are still missing when you’re using the Facebook login to connect to Instagram Insights, [refresh your connection between Supermetrics and Instagram](/v1/docs/instagram-insights-connection-guide). If your accounts are still missing after you've reconnected, [refresh your accounts on the Supermetrics Hub](/v1/docs/how-to-refresh-your-account-data). In Data Studio (formerly Looker Studio), you can [clear the cache to refresh the connection](/v1/docs/how-to-refresh-your-account-data). If your account still isn't appearing after you've checked your permissions and refreshed, take these steps. Note that the steps differ based on your login method: **For Facebook login:** 1. [Log in to Facebook](http://www.facebook.com) with the account that you want to pull data from. 2. In a new tab, [log in to Facebook’s business integrations manager](https://www.facebook.com/settings?tab=business_tools). 3. In the "Active" section, find the business integrations for the connector you're having an issue with. It'll be called either "Supermetrics Connector" for Instagram Insights or "Supermetrics IGPD2" for Instagram Public Data. 4. Click the checkbox to the far right of its name. 5. Click **Remove**. 6. Log out of Facebook and then [reauthenticate your connection](/v1/docs/instagram-insights-connection-guide) to complete the process. **For Instagram login:** 1. In Instagram, go to **Settings → App website permissions → Apps and websites**, or use this [direct link to manage access on Instagram](https://www.instagram.com/accounts/manage_access/). 2. In the Active section, find “Supermetrics Connector-IG”. 3. Click **Remove**. 4. Confirm by clicking **Remove**. 5. Log out of Instagram and then [reauthenticate your connection](/v1/docs/instagram-insights-connection-guide) to complete the process. ****Confirm you've claimed a Facebook Page**** > [!NOTE] > This applies to Instagram Insights with Facebook login only. If you've linked a Facebook Page to your Instagram account but haven't claimed it, the API won't be able to see it. You can find out if your linked Page has been claimed or not by opening the Instagram mobile app while logged in to the linked account, navigating to "Settings", and then "Business". You'll see your account status here. [Learn how to claim a Page in Instagram's documentation](https://help.instagram.com/1338860172903668). ****Check for duplicate Pages**** > [!NOTE] > This applies to Instagram Insights with Facebook login only. Facebook will create a duplicate version of an unmanaged Page when the attached account is converted to a business profile. Additionally, large teams may create multiple versions of the same Page without letting their teammates know. This can lead to your connection to Supermetrics try to reach a version of a Page that your account doesn't have the right to access. This can stop the Page from appearing in Supermetrics. To fix this, verify which Page your Instagram account should link to, and then link them. [Learn how in Meta's documentation](https://www.facebook.com/business/help/345675946300334?id=419087378825961). **Remove multiple logins** Instagram accounts can encounter errors when multiple users are logged in to both Instagram and Facebook at the same time. To fix this, log out of all accounts on Facebook, and then log back in with only the account you want to use with Supermetrics. [Make sure it has the permissions it needs to work with Supermetrics](/v1/docs/about-data-source-permissions-and-access-requirements). ## More resources - [How to fix missing Facebook Pages](/v1/docs/how-to-fix-missing-facebook-pages-and-facebook-ads-accounts) (for Facebook login) - [Good to know about Instagram Insights](/v1/docs/good-to-know-about-instagram-insights)
