--- title: "How to connect to data sources from Supermetrics Hub" slug: "how-to-connect-to-data-sources-from-supermetrics-hub" description: "Connect and manage your data sources effortlessly with Supermetrics Hub. Share links and add new connections to streamline your data access today!" updated: 2026-10-21T12:00:27Z published: 2026-10-21T12:00:27Z canonical: "docs.supermetrics.com/how-to-connect-to-data-sources-from-supermetrics-hub" --- > ## Documentation Index > Fetch the complete documentation index at: https://docs.supermetrics.com/llms.txt > Use this file to discover all available pages before exploring further. # How to connect to data sources from Supermetrics Hub You can connect to all your data sources from the Supermetrics Hub. You can add new connections and share links with external stakeholders to connect to different data sources. > [!NOTE] > More ways to bring your data to Supermetrics > > While we have a wide range of data sources available, sometimes you may need something that we don’t yet have. For those situations, check out [our guide on choosing how to connect your data](/v1/docs/how-to-connect-your-data) — it’ll guide you through the options of building your own connector or working with offline data using Custom data import. ## Getting connected on the Supermetrics Hub On the [Data Sources page on the Hub](https://hub.supermetrics.com/token-management), you can manage your active connections to data sources and add new ones. At the top, you see a list of data sources you have already connected to. Below is a list of data sources that you can connect to. Take a look at our tutorial video on how to connect to data sources, share the authentication link, and reconnect to the data source to resolve connection issues. [Embedded content](https://www.youtube.com/embed/OlZBg0FYMWo) > [!NOTE] > Note > > When you log in to the Supermetrics Hub for the first time, you need to [register your account using this link](https://hub.supermetrics.com/#register). ## Instructions ### Connect to new data source 1. On the [Supermetrics Hub](https://hub.supermetrics.com/), go to **Data sources** under **Connect**. 2. Scroll down to the list of data sources you haven't connected to. You see this list below your existing connections, under the title **Connect to new data source**. 3. Hover over the new data source, and click **Connect**. 4. Choose to make this connection [shared or private](/v1/docs/about-shared-and-private-connections). 5. Depending on the data source, enter your credentials and click **Start**, or click **Start** directly and then log in to the data source. [See our data source guides for the details and permissions each data source requires to connect](/v1/docs/connect). ### Add new connection 1. On the [Supermetrics Hub](https://hub.supermetrics.com/), go to **Data sources** under **Connect**. 2. Go to the list of data sources you have connected to. 3. Click the data source. 4. Click **Add new connection**. 5. Choose to make this connection [shared or private](/v1/docs/about-shared-and-private-connections). 6. Depending on the data source, enter your credentials and click **Start**, or click **Start** directly and then log in to the data source. [See our data source guides for the details and permissions each data source requires to connect](/v1/docs/connect). ### Share authentication link If you need to connect to a data source that you don't have direct access to, you can share an authentication link with someone outside your organization. The person you share the link with must click the link and authenticate the connection to the data source. See detailed instructions for each data source in [our data source guides](/v1/docs/connect). 1. On the [Supermetrics Hub](https://hub.supermetrics.com/), go to **Data sources** under **Connect**. 2. Go to the list of data sources you have connected to. 3. Click the data source. 4. Click **Share authentication link**. You can now share the authentication link with the person who has the necessary credentials. The authentication link is valid for 12 hours. ## More resources - [How to manage data source connections on Supermetrics Hub](/v1/docs/how-to-manage-data-source-connections-on-supermetrics-hub)
