--- title: "How to connect Supermetrics Storage to Data Studio" slug: "how-to-connect-supermetrics-storage-to-data-studio" description: "Learn how to connect Supermetrics Storage to Data Studio and start visualizing your data." updated: 2026-09-25T11:30:06Z published: 2026-09-25T11:30:06Z canonical: "docs.supermetrics.com/how-to-connect-supermetrics-storage-to-data-studio" --- > ## Documentation Index > Fetch the complete documentation index at: https://docs.supermetrics.com/llms.txt > Use this file to discover all available pages before exploring further. # How to connect Supermetrics Storage to Data Studio Follow these steps to connect your Supermetrics Storage to Data Studio (formerly Looker Studio). ## Instructions 1. Go to [Data Studio](https://datastudio.google.com/). 2. On the left, click **Create** → **Data source**. 3. Select the BigQuery connector offered by Google. 4. In **My projects**, select your Supermetrics Storage. 5. Select your dataset. 6. Select your table. 7. Check the **Use DATE as date range dimension** checkbox. 8. Click **Connect**. 9. In the data field preview screen, click **Create report**. 10. Click **Add to report**.
