How to connect data to Qlik Sense
Using the Supermetrics Query Manager, you can easily create queries and connect your data from various data sources to Qlik Sense via the Supermetrics API.
We recommend using the KEY-JSON output format.
See Qlik documentation for more information about creating a REST connection to transfer your data.
  1. On the Supermetrics Hub, go to API queries under Manage.
  2. Click Select data source.
  3. Select a data source and connection to use.
  4. In the sidebar on the left, build your query. Click Run to test it and review your data in the preview.
  5. From the URL format options, select K-JSON.
  6. Copy the K-JSON URL.
  7. Open Qlik Sense, and create a new app.
  8. Continue to add data to the app.
  9. In the Add data view, select the REST option.
  10. In the connection configuration view, paste the Query URL you copied from the Query Manager in step 7 into the URL field and select a name for the connection.
  11. Click Test connection to ensure the configuration is valid.
  12. To finalize the setup, click Create.
