--- title: "Google Merchant Center connection guide" slug: "google-merchant-center-connection-guide" description: "Connect your Google Merchant Center data to Supermetrics with our guide on permissions, query types, and connection instructions for seamless data access." updated: 2026-07-08T09:01:07Z published: 2026-07-08T09:01:07Z canonical: "docs.supermetrics.com/google-merchant-center-connection-guide" --- > ## Documentation Index > Fetch the complete documentation index at: https://docs.supermetrics.com/llms.txt > Use this file to discover all available pages before exploring further. # Google Merchant Center connection guide This guide contains all permissions and requirements for connecting your Google Merchant Center data to Supermetrics. You can connect to data sources from the [Data sources page on the Supermetrics Hub](https://hub.supermetrics.com/token-management). On the Hub, you can also [share an authentication link](https://docs.supermetrics.com/v1/docs/how-to-connect-to-data-sources-from-supermetrics-hub#share-authentication-link) to connect to a data source you don't have direct access to. After you connect to the data source on the Hub, you can use the data source connection in [all available destinations](/docs/google-merchant-center-connection-guide#connection-instructions). ## Required permissions You must have both the **Standard** and **Reporting manager** permissions in the Google Merchant Center account you want to pull data from. ## Query types Query types define what sort of metrics and dimensions are available. You need to select one of the following query types when pulling data: - **Performance**: Retrieve merchant performance metrics matching the search query and optionally segmented by selected dimensions. - **Product**: Offers an overview of all your products. - **Diagnostics**: Offers issue reporting across your account and items grouped by the context in which your product data might show. ## Connection instructions When connecting to Google Merchant Center, you need to log in to Google and select the account to use. 1. Select the Google Merchant Center data source [on the Supermetrics Hub](https://hub.supermetrics.com/token-management) or in the data destination. 2. If prompted, choose to make this connection [shared or private](/v1/docs/about-shared-and-private-connections). 3. Click **Start**. 4. Select the Google account associated with your Google Merchant Center account where you want to fetch data from. 5. Click **Allow** to allow the Supermetrics app to access your profile data. 6. In your data destination, select the query type to use. See detailed instructions on [how to connect to a data source from the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-connect-to-data-sources-from-supermetrics-hub). You can also connect to Google Merchant Center from these destinations: - Google Sheets: [How to connect to a Supermetrics data source in Google Sheets](https://docs.supermetrics.com/docs/how-to-connect-to-a-supermetrics-data-source-in-google-sheets) - Data Studio: [How to connect data sources to Data Studio](/v1/docs/how-to-connect-data-sources-to-data-studio) - Excel: [How to connect data sources to Excel with Supermetrics](https://docs.supermetrics.com/docs/how-to-connect-data-sources-to-excel-with-supermetrics) - Power BI: [How to create your first Supermetrics query for Power BI](https://docs.supermetrics.com/docs/how-to-create-your-first-supermetrics-query-for-power-bi) - The Supermetrics API: [How to use the Query Manager](https://docs.supermetrics.com/docs/how-to-use-the-query-manager) - Data warehouse and cloud storage (Hub): [How to create a transfer](https://docs.supermetrics.com/docs/how-to-create-a-transfer) - BigQuery (marketplace): [How to create a BigQuery (marketplace) transfer](https://docs.supermetrics.com/v1/docs/how-to-create-a-bigquery-marketplace-transfer) ## More resources - [How to reauthenticate a data source connection](/v1/docs/how-to-reauthenticate-a-data-source-connection) - [How to manage data source connections on the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-manage-data-source-connections-on-supermetrics-hub)
