--- title: "Facebook Billing Data connection guide" slug: "facebook-billing-data-connection-guide" description: "Connect your Facebook Billing Data to Supermetrics with Finance Editor access. Get invoice data, campaign insights, and more for effective reporting." updated: 2026-07-08T09:01:35Z published: 2026-07-08T09:01:35Z canonical: "docs.supermetrics.com/facebook-billing-data-connection-guide" --- > ## Documentation Index > Fetch the complete documentation index at: https://docs.supermetrics.com/llms.txt > Use this file to discover all available pages before exploring further. # Facebook Billing Data connection guide This guide contains all permissions and requirements for connecting your Facebook Billing Data data to Supermetrics. You can connect to data sources from the [Data sources page on the Supermetrics Hub](https://hub.supermetrics.com/token-management). On the Hub, you can also [share an authentication link](https://docs.supermetrics.com/v1/docs/how-to-connect-to-data-sources-from-supermetrics-hub#share-authentication-link) to connect to a data source you don't have direct access to. After you connect to the data source on the Hub, you can use the data source connection in [all available destinations](/docs/facebook-billing-data-connection-guide#connection-instructions). ## Required permissions To connect Supermetrics to Facebook Billing Data, you need the **Finance Editor** access level. [Learn more about Facebook Business Manager permissions](https://www.facebook.com/business/help/442345745885606?id=180505742745347). You also need to have monthly invoicing enabled for your Facebook Business Manager account to get its invoice data. Supermetrics can't pull data on transactions that aren't part of a monthly billing cycle. [Learn more about monthly invoicing](https://www.facebook.com/business/help/663802094015925?id=2356205651275420). You can query your lists of invoices and invoicing amounts, as well as rich metadata, campaign, and performance data for each invoice. ## Connection instructions When connecting to Facebook Billing Data, you need to log in to Facebook and select the accounts to pull data from when prompted. 1. Select the Facebook Billing Data data source [on the Supermetrics Hub](https://hub.supermetrics.com/token-management) or in the data destination. 2. If prompted, choose to make this connection [shared or private](/v1/docs/about-shared-and-private-connections). 3. Click **Start**. 4. Either log in with a new Facebook account, or click **Continue as** to go ahead with the account you're already logged in to. 5. Select the Businesses you want to include in your reporting. 6. Review the permissions, and click **Save**. 7. Click **Got it**. 8. In your data destination, select the accounts you'd like to include in your reporting. See detailed instructions on [how to connect to a data source from the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-connect-to-data-sources-from-supermetrics-hub). You can also connect to Facebook Billing Data from these destinations: - Google Sheets: [How to connect to a Supermetrics data source in Google Sheets](https://docs.supermetrics.com/docs/how-to-connect-to-a-supermetrics-data-source-in-google-sheets) - Data Studio: [How to connect data sources to Data Studio](/v1/docs/how-to-connect-data-sources-to-data-studio) - Power BI: [How to create your first Supermetrics query for Power BI](https://docs.supermetrics.com/docs/how-to-create-your-first-supermetrics-query-for-power-bi) - The Supermetrics API: [How to use the Query Manager](https://docs.supermetrics.com/docs/how-to-use-the-query-manager) - Data warehouse and cloud storage (Hub): [How to create a transfer](https://docs.supermetrics.com/docs/how-to-create-a-transfer) - BigQuery (marketplace): [How to create a BigQuery (marketplace) transfer](https://docs.supermetrics.com/v1/docs/how-to-create-a-bigquery-marketplace-transfer) ## More resources - [Facebook Billing Data: Query setup guide](/v1/docs/facebook-billing-data-report-building-guide) - [How to reauthenticate a data source connection](/v1/docs/how-to-reauthenticate-a-data-source-connection) - [How to manage data source connections on the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-manage-data-source-connections-on-supermetrics-hub)
