Entry conditions determine when profiles enter audiences or journeys. Exit conditions determine when they leave. Together, they control the lifecycle of activation and prevent wasted effort or wrong targeting.
Entry conditions
An entry condition is the rule that determines when a profile enters an orchestration object:
In an audience, entry conditions control when a profile becomes a member.
In a journey, entry conditions control when a profile starts the sequence.
Entry is a point in time. It's the moment the rule becomes true, and the profile is admitted.
Entry in audiences
For audiences, entry conditions define membership. Profiles can enter and leave over time as data changes.
Pattern | Example condition |
Suppression | Customer status = active |
Retargeting | Viewed product in the last 7 days |
Value segment | Loyalty tier = gold OR lifetime value > threshold |
Behavioral | Started checkout in the last 24 hours |
When an audience is synced to a destination, entry typically results in an "add" update.
Entry in journeys
For journeys, entry conditions decide when a profile begins a sequence. After entry, the profile moves through steps even if the original entry condition is no longer true.
Journey entry conditions should be framed as triggers rather than ongoing states.
Cart abandonment | Cart started event |
Onboarding | Account created event |
Churn prevention | Contract end date within 30 days |
Win-back | Inactive for 60 days |
Entry condition best practices
Tie the entry to a single marketing decision. Avoid conditions that try to do too much.
Use signals that are reliably available. Entry only works if the required data is present at the moment of evaluation.
Consider identity at the moment of entry. Anonymous visitors can enter, but may have limited activation options until they become known.
Exit conditions
An exit condition removes a profile from an orchestration object after it has entered the orchestration:
In an audience, exit conditions remove profiles from membership when a defined change happens.
In a journey, exit conditions stop the journey for a profile when it's no longer relevant.
Exit conditions prevent wasted activation and keep messaging aligned with the customer's prior actions. Wasted activation results in wasted ad spend down the line, for example, when you don't exclude the recently purchased customer from your paid retargeting audience with a proper exit condition.
Exit in audiences
Exit conditions in audiences keep membership accurate. Without exit conditions, suppression lists become stale, and retargeting continues after conversion.
Pattern | Exit condition |
Conversion | Purchase completed |
Suppression | Status changed to inactive |
Consent | Consent withdrawn |
Value change | Tier dropped below the threshold |
Exit in journeys
Exit conditions in journeys stop the flow when the goal is achieved or the journey no longer applies. Journeys often have multiple exit conditions because there are multiple valid completion states.
Cart recovery | Purchase completed |
Onboarding | First value action completed |
Win-back | Renewal confirmed |
Churn prevention | Upgrade or renewal completed |
Exit vs. inverse entry logic
Exit and inverse entry logic are different tools you can use to target specific users under certain conditions. Use inverse logic to avoid obvious waste at the start. Use exit conditions to stop activation as soon as the outcome occurs.
Inverse logic in entry rules prevents entry in the first place:
Example: Enter only if "has not purchased in the last 24 hours"
Use when you want the audience to consist only of non-converters.
Exit conditions allow entry, then remove profiles when an event occurs:
Example: Enter on "cart started", exit on "purchase completed"
Use for funnel recovery where membership should respond to completion.
Guardrails: disqualifying states
Beyond completion events, add exit conditions for states where activation would be wrong:
Consent withdrawn
Account closed
Customer in service escalation
Fraud or testing flags
These are safety guardrails that prevent reputational damage.
Re-entry considerations
For journeys, decide whether profiles can re-enter after exiting. A common mistake is allowing re-entry when the entry event fires repeatedly (like page views), causing the same profile to enter multiple times.
Setting | Behavior |
No re-entry | Profile can only go through the journey once |
Allow re-entry | Profile can enter again if they meet entry conditions after exiting |
Re-entry with a delay | Profile can re-enter after a waiting period |
Common entry and exit condition issues
Issue | Cause | Fix |
Journey syncs profiles after conversion | Missing exit condition | Add an exit on the conversion event. |
Audience includes converters | Exit not configured or event not tracked | Add an exit condition and verify event ingestion. |
Profiles enter repeatedly | Re-entry allowed with a frequent entry event | Disable re-entry or use a different trigger. |
Exit not triggering | Exit event not being sent | Verify event instrumentation. |
