--- title: "Ecwid connection guide" slug: "ecwid-connection-guide" description: "Connect your Ecwid data to Supermetrics with our guide. Learn to retrieve your Store ID, create a Secret app token, and fetch order data easily." updated: 2026-07-08T09:01:35Z published: 2026-07-08T09:01:35Z canonical: "docs.supermetrics.com/ecwid-connection-guide" --- > ## Documentation Index > Fetch the complete documentation index at: https://docs.supermetrics.com/llms.txt > Use this file to discover all available pages before exploring further. # Ecwid connection guide This guide contains all permissions and requirements for connecting your Ecwid data to Supermetrics. You can connect to data sources from the [Data sources page on the Supermetrics Hub](https://hub.supermetrics.com/token-management). On the Hub, you can also [share an authentication link](https://docs.supermetrics.com/v1/docs/how-to-connect-to-data-sources-from-supermetrics-hub#share-authentication-link) to connect to a data source you don't have direct access to. After you connect to the data source on the Hub, you can use the data source connection in [all available destinations](/docs/ecwid-connection-guide#connection-instructions). ## Required permissions You will need your **Store ID** and **Secret app token** to connect to Ecwid. #### How to retrieve your Store ID - Go to the admin dashboard of your [Ecwid store](https://my.ecwid.com/). - The **Store ID** is visible in the footer section of every page. - It’s also included in the URL of the web page, for example, “[https://my.ecwid.com/store/1234567](https://my.ecwid.com/store/1234567)“ where 1234567 is the Store ID. #### How to create your Secret app token - Go to the [app dashboard](https://my.ecwid.com/#develop-apps) of your Ecwid store. - Click **Create**, next to “Add new app”. - On the app detail page, click **Show secret token**. - Copy the secret token to a secure place for use later. ## Query types If prompted, you need to select a query type to pull data. - **Orders**: Fetch data of all the orders made in a certain time range. ## Connection instructions When connecting to Ecwid, you need to enter your Store ID and Secret app token. 1. Select the Ecwid data source [on the Supermetrics Hub](https://hub.supermetrics.com/token-management) or in the data destination. 2. Insert your **Store ID** and **Secret app token**. 3. If prompted, choose to make this connection [shared or private](/v1/docs/about-shared-and-private-connections). 4. Click **Start**. 5. In your data destination, choose your desired store(s), date range metrics, and dimensions. For Query options settings, select “Fetch orders by created or updated date.” See detailed instructions on [how to connect to a data source from the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-connect-to-data-sources-from-supermetrics-hub). You can also connect to Ecwid from these destinations: - Google Sheets: [How to connect to a Supermetrics data source in Google Sheets](https://docs.supermetrics.com/docs/how-to-connect-to-a-supermetrics-data-source-in-google-sheets) - Data Studio: [How to connect data sources to Data Studio](/v1/docs/how-to-connect-data-sources-to-data-studio) - Excel: [How to connect data sources to Excel with Supermetrics](https://docs.supermetrics.com/docs/how-to-connect-data-sources-to-excel-with-supermetrics) - Power BI: [How to create your first Supermetrics query for Power BI](https://docs.supermetrics.com/docs/how-to-create-your-first-supermetrics-query-for-power-bi) - The Supermetrics API: [How to use the Query Manager](https://docs.supermetrics.com/docs/how-to-use-the-query-manager) - Data warehouse and cloud storage (Hub): [How to create a transfer](https://docs.supermetrics.com/docs/how-to-create-a-transfer) - BigQuery (marketplace): [How to create a BigQuery (marketplace) transfer](https://docs.supermetrics.com/v1/docs/how-to-create-a-bigquery-marketplace-transfer) ## More resources - [How to reauthenticate a data source connection](/v1/docs/how-to-reauthenticate-a-data-source-connection) - [How to manage data source connections on the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-manage-data-source-connections-on-supermetrics-hub)
