--- title: "Criteo Retail Media connection guide" slug: "criteo-retail-media-connection-guide" description: "Connect your Criteo Retail Media data to Supermetrics with our guide on permissions, query types, and connection instructions for seamless data integration." tags: ["Paid media"] updated: 2026-07-08T09:01:35Z published: 2026-07-08T09:01:35Z canonical: "docs.supermetrics.com/criteo-retail-media-connection-guide" --- > ## Documentation Index > Fetch the complete documentation index at: https://docs.supermetrics.com/llms.txt > Use this file to discover all available pages before exploring further. # Criteo Retail Media connection guide This guide contains all permissions and requirements for connecting your Criteo Retail Media data to Supermetrics. You can connect to data sources from the [Data sources page on the Supermetrics Hub](https://hub.supermetrics.com/token-management). On the Hub, you can also [share an authentication link](https://docs.supermetrics.com/v1/docs/how-to-connect-to-data-sources-from-supermetrics-hub#share-authentication-link) to connect to a data source you don't have direct access to. After you connect to the data source on the Hub, you can use the data source connection in [all available destinations](/docs/criteo-retail-media-connection-guide#connection-instructions). ## Required permissions Before using the Criteo Retail Media connector, you need: - An **API user** with a **client ID** and **client secret**. - An app with at least **Read** access for all elements of the Retail Media API. To create these credentials, follow our [Criteo permissions guide](/v1/docs/criteo-permissions-guide). ## Query types Query types define what sort of metrics and dimensions are available. You need to select one of the following query types when pulling data: - **Campaign**: An overview of the performance of a specific advertising campaign over a given period of time using the Clicks, Impressions, CTR, CPM, Attributed orders, Units, Sales, Cost, CPC, Unique visitors, and Frequency metrics - **Page type**: Campaign data split by Page type - **Product**: Campaign data split by Product - **Keyword**: Campaign data split by Keyword - **Attributed transactions**: Insights into the performance of ad campaigns by attributing conversions to specific advertising initiatives ## Connection instructions When connecting to Criteo Retail Media, you need to provide your Criteo credentials. 1. Select the Criteo Retail Media data source [on the Supermetrics Hub](https://hub.supermetrics.com/token-management) or in the data destination. 2. Enter the client ID and client secret. 3. Give your login a name to recognize the login later in case you have multiple logins. 4. If prompted, choose to make this connection [shared or private](/v1/docs/about-shared-and-private-connections). 5. Click **Start**. 6. In your data destination, select a query type to use. See detailed instructions on [how to connect to a data source from the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-connect-to-data-sources-from-supermetrics-hub). You can also connect to Criteo Retail Media from these destinations: - Google Sheets: [How to connect to a Supermetrics data source in Google Sheets](https://docs.supermetrics.com/docs/how-to-connect-to-a-supermetrics-data-source-in-google-sheets) - Data Studio: [How to connect data sources to Data Studio](/v1/docs/how-to-connect-data-sources-to-data-studio) - Excel: [How to connect data sources to Excel with Supermetrics](https://docs.supermetrics.com/docs/how-to-connect-data-sources-to-excel-with-supermetrics) - Power BI: [How to create your first Supermetrics query for Power BI](https://docs.supermetrics.com/docs/how-to-create-your-first-supermetrics-query-for-power-bi) - The Supermetrics API: [How to use the Query Manager](https://docs.supermetrics.com/docs/how-to-use-the-query-manager) - Data warehouse and cloud storage (Hub): [How to create a transfer](https://docs.supermetrics.com/docs/how-to-create-a-transfer) - BigQuery (marketplace): [How to create a BigQuery (marketplace) transfer](https://docs.supermetrics.com/v1/docs/how-to-create-a-bigquery-marketplace-transfer) ## More resources - [How to reauthenticate a data source connection](/v1/docs/how-to-reauthenticate-a-data-source-connection) - [How to manage data source connections on the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-manage-data-source-connections-on-supermetrics-hub)
