--- title: "ChatGPT Ads connection guide" slug: "chatgpt-ads-connection-guide" description: "Connect your Awin data to Supermetrics with our guide. Learn about permissions, API credentials, and query types for seamless data integration." updated: 2026-08-06T06:13:18Z published: 2026-08-06T06:13:18Z canonical: "docs.supermetrics.com/chatgpt-ads-connection-guide" --- > ## Documentation Index > Fetch the complete documentation index at: https://docs.supermetrics.com/llms.txt > Use this file to discover all available pages before exploring further. # ChatGPT Ads connection guide This guide contains all permissions and requirements for connecting your ChatGPT Ads data to Supermetrics. You can connect to data sources from the [Data sources page on the Supermetrics Hub](https://hub.supermetrics.com/token-management). On the Hub, you can also [share an authentication link](https://docs.supermetrics.com/v1/docs/how-to-connect-to-data-sources-from-supermetrics-hub#share-authentication-link) to connect to a data source you don't have direct access to. After you connect to the data source on the Hub, you can use the data source connection in [all available destinations](/docs/chatgpt-ads-connection-guide#connection-instructions). ## Required permissions To connect Supermetrics to your ChatGPT Ads data, you need an API key generated from the OpenAI Ads Manager. You must have Admin permission to generate API keys. To get the API key: 1. Go to the [OpenAI Ads Manager settings page](https://ads.openai.com/settings). 2. Create a new API key. 3. Copy the generated API key. ## Connection instructions When connecting to ChatGPT Ads, you need to insert your API key when prompted. 1. Select the ChatGPT Ads data source on the [Supermetrics Hub](https://hub.supermetrics.com) or in the data destination. 2. Enter your API key generated from the [OpenAI Ads Manager](https://ads.openai.com/). 3. If prompted, choose to make this connection [shared or private](/v1/docs/about-shared-and-private-connections). 4. Click **Start**. See detailed instructions on [how to connect to a data source from the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-connect-to-data-sources-from-supermetrics-hub). You can also connect to ChatGPT Ads from these destinations: - Google Sheets: [How to connect to a Supermetrics data source in Google Sheets](https://docs.supermetrics.com/docs/how-to-connect-to-a-supermetrics-data-source-in-google-sheets) - Data Studio: [How to connect data sources to Data Studio](/v1/docs/how-to-connect-data-sources-to-data-studio) - Excel: [How to connect data sources to Excel with Supermetrics](https://docs.supermetrics.com/docs/how-to-connect-data-sources-to-excel-with-supermetrics) - Power BI: [How to create your first Supermetrics query for Power BI](https://docs.supermetrics.com/docs/how-to-create-your-first-supermetrics-query-for-power-bi) - The Supermetrics API: [How to use the Query Manager](https://docs.supermetrics.com/docs/how-to-use-the-query-manager) - Data warehouse and cloud storage (Hub): [How to create a transfer](https://docs.supermetrics.com/docs/how-to-create-a-transfer) - BigQuery (marketplace): [How to create a BigQuery (marketplace) transfer](https://docs.supermetrics.com/v1/docs/how-to-create-a-bigquery-marketplace-transfer) ## More resources - [How to reauthenticate a data source connection](/v1/docs/how-to-reauthenticate-a-data-source-connection) - [How to manage data source connections on the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-manage-data-source-connections-on-supermetrics-hub)
