--- title: "Centra connection guide" slug: "centra-connection-guide" description: "Connect your Centra data to Supermetrics with our guide on API tokens, Endpoint URLs, and query types for seamless data integration." updated: 2026-07-08T09:01:35Z published: 2026-07-08T09:01:35Z canonical: "docs.supermetrics.com/centra-connection-guide" --- > ## Documentation Index > Fetch the complete documentation index at: https://docs.supermetrics.com/llms.txt > Use this file to discover all available pages before exploring further. # Centra connection guide This guide contains all permissions and requirements for connecting your Centra data to Supermetrics. You can connect to data sources from the [Data sources page on the Supermetrics Hub](https://hub.supermetrics.com/token-management). On the Hub, you can also [share an authentication link](https://docs.supermetrics.com/v1/docs/how-to-connect-to-data-sources-from-supermetrics-hub#share-authentication-link) to connect to a data source you don't have direct access to. After you connect to the data source on the Hub, you can use the data source connection in [all available destinations](/docs/centra-connection-guide#connection-instructions). ## Required permissions You need an **API token** and an **Endpoint URL** to connect to Centra. ### How to create an API token 1. Log in ot your Centra Dashboard. 2. In the navigation on the left, go to **System → API tokens**. 3. In the top right corner, click **Create integration API token**. 4. Enter the required details such as an expiration date and description so that you can easily identify the API token later, for example “Supermetrics”. 5. In the **Stores** list, select at least one store that you want to fetch data for. 6. Under permissions, select the following **Read permissions**: 1. Order details 2. Order.shippingAddress 3. Return details 4. Shipment details 5. Product details 6. Market details 7. PaymentHistory 8. Store details 9. Currency details 7. Click **Save**. ### How to find your Endpoint URL 1. Log in to your Centra Dashboard. 2. In the navigation on the left, go to **System → API tokens**. 3. The Endpoint URL is visible at the top of the page. It should follow the format “https://shop-name.centra.com/graphql”. ## Query types Query types define what sort of metrics and dimensions are available. You need to select one of the following query types when pulling data: - **Order items** - **Return items** ## Connection instructions When connecting to Centra, you need to log in to Centra and enter your Endpoint URL and API token. 1. Select the Centra data source [on the Supermetrics Hub](https://hub.supermetrics.com/token-management) or in the data destination. 2. Insert the Endpoint URL, API token and give a name for your log in. 3. If prompted, choose to make this connection [shared or private](/v1/docs/about-shared-and-private-connections). 4. Click **Start**. 5. In your data destination, select the store(s) for which you want to fetch data and the query type you want to use. See detailed instructions on [how to connect to a data source from the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-connect-to-data-sources-from-supermetrics-hub). You can also connect to Centra from these destinations: - Google Sheets: [How to connect to a Supermetrics data source in Google Sheets](https://docs.supermetrics.com/docs/how-to-connect-to-a-supermetrics-data-source-in-google-sheets) - Data Studio: [How to connect data sources to Data Studio](/v1/docs/how-to-connect-data-sources-to-data-studio) - Excel: [How to connect data sources to Excel with Supermetrics](https://docs.supermetrics.com/docs/how-to-connect-data-sources-to-excel-with-supermetrics) - Power BI: [How to create your first Supermetrics query for Power BI](https://docs.supermetrics.com/docs/how-to-create-your-first-supermetrics-query-for-power-bi) - The Supermetrics API: [How to use the Query Manager](https://docs.supermetrics.com/docs/how-to-use-the-query-manager) - Data warehouse and cloud storage (Hub): [How to create a transfer](https://docs.supermetrics.com/docs/how-to-create-a-transfer) - BigQuery (marketplace): [How to create a BigQuery (marketplace) transfer](https://docs.supermetrics.com/v1/docs/how-to-create-a-bigquery-marketplace-transfer) ## More resources - [How to reauthenticate a data source connection](/v1/docs/how-to-reauthenticate-a-data-source-connection) - [How to manage data source connections on the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-manage-data-source-connections-on-supermetrics-hub)
