--- title: "Celtra connection guide" slug: "celtra-connection-guide" description: "Connect your Celtra data to Supermetrics with our guide. Learn about permissions, API setup, and query types for seamless data integration." updated: 2026-07-08T09:01:35Z published: 2026-07-08T09:01:35Z canonical: "docs.supermetrics.com/celtra-connection-guide" --- > ## Documentation Index > Fetch the complete documentation index at: https://docs.supermetrics.com/llms.txt > Use this file to discover all available pages before exploring further. # Celtra connection guide This guide contains all permissions and requirements for connecting your Celtra data to Supermetrics. You can connect to data sources from the [Data sources page on the Supermetrics Hub](https://hub.supermetrics.com/token-management). On the Hub, you can also [share an authentication link](https://docs.supermetrics.com/v1/docs/how-to-connect-to-data-sources-from-supermetrics-hub#share-authentication-link) to connect to a data source you don't have direct access to. After you connect to the data source on the Hub, you can use the data source connection in [all available destinations](/docs/celtra-connection-guide#connection-instructions). ## Required permissions To connect Supermetrics to your Celtra account, you need to get your Celtra Account ID and to create an API application inside Celtra. ****Get your account ID**** 1. Log in to Celtra, and open your dashboard. 2. Go to the **Reporting Center**. 3. Click the green **+** button on the right to open the report builder. 4. In “Search dimensions”, enter “Account ID”. 5. In “Search metrics”, select any metric from the list. 6. Click **Generate report**. 7. Copy your Account ID from the report to use later. ****Create your API app**** 1. Log in to Celtra, and open your dashboard. 2. Click your name in the top right of the navigation bar and select **Settings**. 3. Select the **API Apps** tab. 4. Click **Add API App**. 5. Enter a name for the app, for example, “Supermetrics”. 6. Click **Save** to create the API app. 7. Copy the App ID from the list and copy it for later. 8. Under **Secret Key**, click **Show Key**. 9. Copy this key and store it in a secure place for later. ## Query types If prompted, you need to select a query type to pull data. - **Campaign performance**: Measure the performance of your creatives on different platforms. ## Connection instructions When connecting to Celtra, you need to insert the account ID, app ID, and secret key and select the accounts to use when prompted. 1. Select the Celtra data source [on the Supermetrics Hub](https://hub.supermetrics.com/token-management) or in the data destination. 2. Enter your Account ID, App ID, and Secret Key. 3. Give your login a name. The name can be anything — its purpose is for you to recognize the login later in case you have multiple logins. 4. If prompted, choose to make this connection [shared or private](/v1/docs/about-shared-and-private-connections). 5. Click **Start**. 6. In your data destination, select the accounts to use in your reporting and a query type, if prompted. See detailed instructions on [how to connect to a data source from the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-connect-to-data-sources-from-supermetrics-hub). You can also connect to Celtra from these destinations: - Google Sheets: [How to connect to a Supermetrics data source in Google Sheets](https://docs.supermetrics.com/docs/how-to-connect-to-a-supermetrics-data-source-in-google-sheets) - Data Studio: [How to connect data sources to Data Studio](/v1/docs/how-to-connect-data-sources-to-data-studio) - Excel: [How to connect data sources to Excel with Supermetrics](https://docs.supermetrics.com/docs/how-to-connect-data-sources-to-excel-with-supermetrics) - Power BI: [How to create your first Supermetrics query for Power BI](https://docs.supermetrics.com/docs/how-to-create-your-first-supermetrics-query-for-power-bi) - The Supermetrics API: [How to use the Query Manager](https://docs.supermetrics.com/docs/how-to-use-the-query-manager) - Data warehouse and cloud storage (Hub): [How to create a transfer](https://docs.supermetrics.com/docs/how-to-create-a-transfer) - BigQuery (marketplace): [How to create a BigQuery (marketplace) transfer](https://docs.supermetrics.com/v1/docs/how-to-create-a-bigquery-marketplace-transfer) ## More resources - [How to reauthenticate a data source connection](/v1/docs/how-to-reauthenticate-a-data-source-connection) - [How to manage data source connections on the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-manage-data-source-connections-on-supermetrics-hub)
