--- title: "Awin connection guide" slug: "awin-connection-guide" description: "Connect your Awin data to Supermetrics with our guide. Learn about permissions, API credentials, and query types for seamless data integration." updated: 2026-10-28T08:16:36Z published: 2026-10-28T08:16:36Z canonical: "docs.supermetrics.com/awin-connection-guide" --- > ## Documentation Index > Fetch the complete documentation index at: https://docs.supermetrics.com/llms.txt > Use this file to discover all available pages before exploring further. # Awin connection guide This guide contains all permissions and requirements for connecting your Awin data to Supermetrics. You can connect to data sources from the [Data sources page on the Supermetrics Hub](https://hub.supermetrics.com/token-management). On the Hub, you can also [share an authentication link](https://docs.supermetrics.com/v1/docs/how-to-connect-to-data-sources-from-supermetrics-hub#share-authentication-link) to connect to a data source you don't have direct access to. After you connect to the data source on the Hub, you can use the data source connection in [all available destinations](/docs/awin-connection-guide#connection-instructions). ## Required permissions To connect Supermetrics to Awin, you need Awin API credentials. 1. Go to the [Awin API credentials page](https://ui.awin.com/awin-api). 2. Enter your Awin password and click **Show my API token**. 3. Copy the API token. [Learn more about how to create these credentials in the Awin wiki](https://wiki.awin.com/index.php/API_authentication). ## Query types Query types define what sort of metrics and dimensions are available. You need to select one of the following query types when pulling data: - **Publisher report**: Get aggregate performance metrics, like impressions and transactions, per publisher. - **Creative report**: Fetch aggregate performance metrics, like impressions and transactions, per creative used. - **Transactions report**: Pull all individual transactions to check their status and commissions paid. ## Connection instructions When connecting to Awin, you need to insert your API key (API token) and select the accounts and query type to use when prompted. 1. Select the Awin data source [on the Supermetrics Hub](https://hub.supermetrics.com/token-management) or in the data destination. 2. Enter your API key. 3. Give your login a name. The name can be anything — its purpose is for you to recognize the login later in case you have multiple logins. 4. If prompted, choose to make this connection [shared or private](/v1/docs/about-shared-and-private-connections). 5. Click **Start**. 6. In your data destination, select the accounts and query type to use. See detailed instructions on [how to connect to a data source from the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-connect-to-data-sources-from-supermetrics-hub). You can also connect to Awin from these destinations: - **AI tools and dashboards:** - AI chats: [How to connect Supermetrics to AI tools](/v1/docs/how-to-connect-supermetrics-to-ai-tools) - Supermetrics Studio: [How to create dashboards in Supermetrics Studio](/v1/docs/how-to-create-dashboards-in-supermetrics-studio) - **Spreadsheet and data visualization tools:** - Google Sheets: [How to connect to a Supermetrics data source in Google Sheets](https://docs.supermetrics.com/docs/how-to-connect-to-a-supermetrics-data-source-in-google-sheets) - Data Studio: [How to connect data sources to Data Studio](/v1/docs/how-to-connect-data-sources-to-data-studio) - Excel: [How to connect data sources to Excel with Supermetrics](https://docs.supermetrics.com/docs/how-to-connect-data-sources-to-excel-with-supermetrics) - Power BI: [How to create your first Supermetrics query for Power BI](https://docs.supermetrics.com/docs/how-to-create-your-first-supermetrics-query-for-power-bi) - **Data warehouses and cloud storage:** - The Supermetrics API: [How to use the Query Manager](https://docs.supermetrics.com/docs/how-to-use-the-query-manager) - Data warehouse and cloud storage (Hub): [How to create a transfer](https://docs.supermetrics.com/docs/how-to-create-a-transfer) - BigQuery (marketplace): [How to create a BigQuery (marketplace) transfer](https://docs.supermetrics.com/v1/docs/how-to-create-a-bigquery-marketplace-transfer) ## More resources - [Awin report building guide](/v1/docs/awin-report-building-guide) - [How to reauthenticate a data source connection](/v1/docs/how-to-reauthenticate-a-data-source-connection) - [How to manage data source connections on the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-manage-data-source-connections-on-supermetrics-hub)
