--- title: "Amazon Seller Central connection guide" slug: "amazon-seller-central-connection-guide" description: "Connect your Amazon Seller Central data to Supermetrics with our guide on permissions, query types, and troubleshooting for seamless reporting." updated: 2026-10-28T08:09:22Z published: 2026-10-28T08:09:22Z canonical: "docs.supermetrics.com/amazon-seller-central-connection-guide" --- > ## Documentation Index > Fetch the complete documentation index at: https://docs.supermetrics.com/llms.txt > Use this file to discover all available pages before exploring further. # Amazon Seller Central connection guide This guide contains all permissions and requirements for connecting your Amazon Seller Central data to Supermetrics. You can connect to data sources from the [Data sources page on the Supermetrics Hub](https://hub.supermetrics.com/token-management). On the Hub, you can also [share an authentication link](https://docs.supermetrics.com/v1/docs/how-to-connect-to-data-sources-from-supermetrics-hub#share-authentication-link) to connect to a data source you don't have direct access to. After you connect to the data source on the Hub, you can use the data source connection in [all available destinations](/docs/amazon-seller-central-connection-guide#connection-instructions). ## Required permissions You must be the **primary user** of the Amazon Seller Central account or enabled **Grant universal site admin access** permissions for a secondary user account. To assign admin permissions to a secondary account: 1. Go to **Settings** → **User Permissions** in Amazon Seller Central. 2. Click **Manage permissions**. Before starting the connection process, please check the main marketplace and region for your Amazon Seller account. ## Query types Query types define what sort of metrics and dimensions are available. You need to select one of the following query types when pulling data: - **Sales and traffic by date** - **Sales and traffic by ASIN** - **Orders** ## Connection instructions When connecting to Amazon Seller Central, you need to log in to Amazon and select the marketplaces to include in your report. 1. Select the Amazon Seller Central data source [on the Supermetrics Hub](https://hub.supermetrics.com/token-management) or in the data destination. 2. If prompted, choose to make this connection [shared or private](/v1/docs/about-shared-and-private-connections). 3. Click **Start**. 4. Log in to your Amazon account. 5. Select the marketplace account where you have your main store. 6. Click **Confirm** to authorize the Supermetrics app to access your data. 7. In your data destination, select the marketplaces you'd like to include in your reporting and a query type to use. See detailed instructions on [how to connect to a data source from the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-connect-to-data-sources-from-supermetrics-hub). You can also connect to Amazon Seller Central from these destinations: - **AI tools and dashboards:** - AI chats: [How to connect Supermetrics to AI tools](/v1/docs/how-to-connect-supermetrics-to-ai-tools) - Supermetrics Studio: [How to create dashboards in Supermetrics Studio](/v1/docs/how-to-create-dashboards-in-supermetrics-studio) - **Spreadsheet and data visualization tools:** - Google Sheets: [How to connect to a Supermetrics data source in Google Sheets](https://docs.supermetrics.com/docs/how-to-connect-to-a-supermetrics-data-source-in-google-sheets) - Data Studio: [How to connect data sources to Data Studio](/v1/docs/how-to-connect-data-sources-to-data-studio) - Excel: [How to connect data sources to Excel with Supermetrics](https://docs.supermetrics.com/docs/how-to-connect-data-sources-to-excel-with-supermetrics) - Power BI: [How to create your first Supermetrics query for Power BI](https://docs.supermetrics.com/docs/how-to-create-your-first-supermetrics-query-for-power-bi) - **Data warehouses and cloud storage:** - The Supermetrics API: [How to use the Query Manager](https://docs.supermetrics.com/docs/how-to-use-the-query-manager) - Data warehouse and cloud storage (Hub): [How to create a transfer](https://docs.supermetrics.com/docs/how-to-create-a-transfer) - BigQuery (marketplace): [How to create a BigQuery (marketplace) transfer](https://docs.supermetrics.com/v1/docs/how-to-create-a-bigquery-marketplace-transfer) ## Troubleshooting If you're unable to fetch or select your accounts after connecting Amazon Seller Central to Supermetrics, this is likely due to selecting the wrong marketplace account when setting up the connection. Please try creating a new connection and make sure you select the correct main marketplace and region. ## More resources - [How to reauthenticate a data source connection](/v1/docs/how-to-reauthenticate-a-data-source-connection) - [How to manage data source connections on the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-manage-data-source-connections-on-supermetrics-hub)
