--- title: "About Supermetrics Hub" slug: "about-supermetrics-hub" description: "Learn how to navigate the Supermetrics Hub and get familiar with all features to manage your data, usage, team, and subscription." updated: 2026-10-30T06:04:39Z published: 2026-10-30T06:04:39Z canonical: "docs.supermetrics.com/about-supermetrics-hub" --- > ## Documentation Index > Fetch the complete documentation index at: https://docs.supermetrics.com/llms.txt > Use this file to discover all available pages before exploring further. # About Supermetrics Hub The Supermetrics Hub is a place where you can manage your data sources, accounts, data integrations, and more. - You can connect to new data sources, start new trials, and explore all features. - Use the Data Explorer to take a quick look at your data, or build a query URL to use in other destinations. - To dig deeper into your data, you can create data blends and custom fields on the Hub and use them in your reporting. - And of course, the Hub is the place to manage your teams and subscription details. > [!NOTE] > Note > > When you log in to the Supermetrics Hub for the first time, you need to [register your account using this link](https://hub.supermetrics.com/#register). ## Navigation on the Hub In the left-side menu, you can access the following subpages: - **Home**: Your home page on the Supermetrics Hub. - **Connect** - **Data sources**: [Connect to data sources and manage your data source connections](/v1/docs/how-to-connect-to-data-sources-from-supermetrics-hub). - **Custom data import**: [About Supermetrics Customer Data Import](https://docs.supermetrics.com/docs/about-supermetrics-custom-data-import). - **Connector builder**: [Build your own custom connectors](/v1/docs/connector-builder). - **Manage** - **Custom fields**: [Create custom fields](/v1/docs/about-supermetrics-custom-fields). - **Data blending**: [Blend data from different data sources](/v1/docs/about-data-blending). - **Data warehousing**: [Connect to data warehouse destinations](https://docs.supermetrics.com/docs/how-to-connect-to-a-data-warehouse-destination). - **Table manager**: [Transfer data to data warehouse destinations](https://docs.supermetrics.com/docs/how-to-create-a-transfer). - **Data transfers**: [Monitor your transfers](https://docs.supermetrics.com/docs/how-to-monitor-your-data-warehouse-transfers-on-the-supermetrics-hub). - **Analyze** - **Supermetrics Studio**: [Build live, AI-powered dashboards using Supermetrics connectors](/v1/docs/supermetrics-studio). - **AI chats**: [Work on with your data directly in the AI tools you use, such as ChatGPT and Claude](/v1/docs/how-to-connect-supermetrics-to-ai-tools). - **Destinations**: Go to your external reporting tools — Google Sheets, Data Studio, Excel, and Power BI. - **Data explorer**: [Analyze your marketing data directly on the Supermetrics Hub or export the data in various formats](https://docs.supermetrics.com/docs/data-explorer). From the top bar, you can access the following menus: - Your team name: Click the team name to switch between teams - Help menu button (![A speech bubble with a question mark, indicating a place to go when help is needed.](https://cdn.document360.io/a13cead5-eaae-456f-9bd1-0941d590c0e3/Images/Documentation/hub-help-support-icon.png)): - Links to our support center and status page - Links to useful resources to manage your account - View and submit support tickets - Your avatar: - **Manage your team**: [Add and remove your Supermetrics team members and update their team roles](/v1/docs/how-to-manage-your-supermetrics-team). - **Usage**: [View your data source usage](/v1/docs/how-to-check-your-subscription-usage). - **API keys**: [Create and manage your API keys](/v1-api/apidocs/managing-your-api-keys). - **Subscriptions**: [Manage your Supermetrics subscriptions and assign users to them](/v1/docs/how-to-manage-your-supermetrics-subscription). - **Billing details**: [View and update your billing information](/v1/docs/how-to-manage-your-billing-information-and-billing-cycle). - **Log out**: Log out of the Supermetrics Hub.
