In addition to our gallery of free templates, Supermetrics offers advanced, custom data visualization charts for Looker Studio (formerly Data Studio). They're built by data visualization designers and UX specialists to provide beautiful, custom reporting that's easy to create and maintain.
Note
At the moment, Supermetrics Charts is not available for new customers.
As with all Looker Studio reports, you can publish and share your visualizations with others as you like (though anyone who wants to edit a visualization will need a Supermetrics subscription). Our visualizations work with every type of data that Looker Studio supports, though they don't work with data controls.
Chart types
Bullet graph
Get an overview of your targets with this progress bar-style graph. Learn more about this visualization.
Combo scorecard
Present a single KPI or multiple key metrics and compare it to another time frame or another metric. Learn more about this visualization.
Funnel
Identify drop-off points and segment behavior in any stepped process. Learn more about this visualization.
Gauges and progress bars
Compare and track metrics over time with either radial or linear progress bars. Learn more about this visualization.
Maps
Use a screengrid, heatmap, or hexagon map to visualize spatial distribution. Learn more about this visualization.
Maps slideshow (BigQuery only)
Use BigQuery to import custom maps — each on their own slide — with a heatmap layer into Looker Studio. Learn more about this visualization.
Return on advertising spend
Create a fully customized report to track your return on ad spend and progress. Add a dimension to explore the details. Learn more about this visualization.
Scorecards
Use scorecards with bar or line graphs to combine multiple performance indicators and break them down by dimension. Add custom metrics and dates to each. Learn more about this visualization.
Simple bar chart
Compare up to 16 metrics while keeping the scale, and compare with another metric or date range. Learn more about this visualization.
Tell me
Enhance your reports with simple, dynamic, data-driven sentences or text snippets, and tell your readers in one sentence what they should take away from a report page. Learn more about this visualization.
Tile grid map
Use pre-defined map configurations or create your own custom map. The tile grid map isn't applicable just to geographical data — it can also be used as a custom heatmap for many data sources. Learn more about this visualization.
Timebrush tool
The timebrush is a tool that helps you quickly filter other charts on your page.
It displays the current timeframe of the dataset. Click and drag to select one or a range of bars and filter the whole report to that timeframe.
Learn more about the timebrush tool.
Tree
Create a tree or sunburst diagram from hierarchical data using only a URL or file path for one metric. Learn more about this visualization.
User journey
Discover how users navigate your website or find the spots where your funnel fails. Learn more about this visualization.
