--- title: "Yelp Reviews connection guide" slug: "yelp-reviews-connection-guide" description: "Connect your Yelp Reviews data to Supermetrics easily with our guide. Learn about permissions, query types, and connection instructions for seamless reporting." updated: 2026-07-08T11:55:44Z published: 2026-07-08T11:55:44Z canonical: "docs.supermetrics.com/yelp-reviews-connection-guide" --- > ## Documentation Index > Fetch the complete documentation index at: https://docs.supermetrics.com/llms.txt > Use this file to discover all available pages before exploring further. # Yelp Reviews connection guide This guide contains all permissions and requirements for connecting your Yelp Reviews data to Supermetrics. You can connect to data sources from the [Data sources page on the Supermetrics Hub](https://hub.supermetrics.com/token-management). On the Hub, you can also [share an authentication link](https://docs.supermetrics.com/v1/docs/how-to-connect-to-data-sources-from-supermetrics-hub#share-authentication-link) to connect to a data source you don't have direct access to. After you connect to the data source on the Hub, you can use the data source connection in [all available destinations](/docs/yelp-reviews-connection-guide#connection-instructions). ## Required permissions You need a business' Yelp Business ID before you can pull its review data from Yelp Reviews. You can find any Yelp Business ID by copying the text that comes after `/biz` in the URL for any business' Yelp page. For example, if you opened the Yelp page for a business called Article Example Business, its URL would end with `/biz/article-example-business`. Here, the business's Yelp Business ID is `article-example-business`. ## Query types If prompted, you need to select a query type to pull data. - **Reviews**: Get data for up to 100 of the most recent reviews. ## Connection instructions When connecting to Yelp Reviews, you need to enter the Yelp Business ID to query. 1. Select the Yelp Reviews data source [on the Supermetrics Hub](https://hub.supermetrics.com/token-management) or in the data destination. 2. If prompted, choose to make this connection [shared or private](/v1/docs/about-shared-and-private-connections). 3. Click **Start**. 4. In your data destination, select a query type, if prompted, and the Yelp Business ID to include in your reporting. See detailed instructions on [how to connect to a data source from the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-connect-to-data-sources-from-supermetrics-hub). You can also connect to Yelp Reviews from these destinations: - Google Sheets: [How to connect to a Supermetrics data source in Google Sheets](https://docs.supermetrics.com/docs/how-to-connect-to-a-supermetrics-data-source-in-google-sheets) - Data Studio: [How to connect data sources to Data Studio](/v1/docs/how-to-connect-data-sources-to-data-studio) - Excel: [How to connect data sources to Excel with Supermetrics](https://docs.supermetrics.com/docs/how-to-connect-data-sources-to-excel-with-supermetrics) - Power BI: [How to create your first Supermetrics query for Power BI](https://docs.supermetrics.com/docs/how-to-create-your-first-supermetrics-query-for-power-bi) - The Supermetrics API: [How to use the Query Manager](https://docs.supermetrics.com/docs/how-to-use-the-query-manager) ## More resources - [How to reauthenticate a data source connection](/v1/docs/how-to-reauthenticate-a-data-source-connection) - [How to manage data source connections on the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-manage-data-source-connections-on-supermetrics-hub)
