--- title: "Wix Commerce connection guide" slug: "wix-commerce-connection-guide" description: "Connect your Wix Commerce data to Supermetrics with our guide. Learn about API keys, Account IDs, and data source connections for seamless integration." updated: 2026-07-08T11:55:44Z published: 2026-07-08T11:55:44Z canonical: "docs.supermetrics.com/wix-commerce-connection-guide" stale: true --- > ## Documentation Index > Fetch the complete documentation index at: https://docs.supermetrics.com/llms.txt > Use this file to discover all available pages before exploring further. # Wix Commerce connection guide This guide contains all permissions and requirements for connecting your Wix Commerce data to Supermetrics. You can connect to data sources from the [Data sources page on the Supermetrics Hub](https://hub.supermetrics.com/token-management). On the Hub, you can also [share an authentication link](https://docs.supermetrics.com/v1/docs/how-to-connect-to-data-sources-from-supermetrics-hub#share-authentication-link) to connect to a data source you don't have direct access to. After you connect to the data source on the Hub, you can use the data source connection in [all available destinations](/docs/wix-commerce-connection-guide#connection-instructions). ## Required permissions You need an **API key** and your **Account ID** in order to connect to Wix Commerce. You can manage your API key and account ID in your [Wix dashboard](https://manage.wix.com/account/api-keys). ## How to create an API key 1. Log in to your [Wix dashboard](https://manage.wix.com/). 2. Open the [API keys management page](https://manage.wix.com/account/api-keys). 3. In the top-right corner, click **Generate API Key**. 4. Enter a name for your API key, for example “Supermetrics”. 5. Add the following API permissions: a. Basic Permissions - Get Sites List b. All Site Permissions - Wix eCommerce 6. Click **Generate Key**. 7. Click **Send Code** to send a 6-digit verification code to the email address linked to your account. 8. Get your verification code from your email. 9. Enter the code in the Verify your account pop-up. 10. Click **Verify and Generate Key**. ## How to find your Account ID 1. Log in to your [Wix dashboard](https://manage.wix.com/). 2. Open the [API keys management page](https://manage.wix.com/account/api-keys). 3. The **Account ID** is visible on the right-hand side. ## Query types If prompted, you need to select a query type to pull data. - Orders ## Connection instructions When connecting to Wix Commerce, you need to provide your API key and Account ID. 1. Select the Wix Commerce data source [on the Supermetrics Hub](https://hub.supermetrics.com/token-management) or in the data destination. 2. Insert your API key, account ID and give a name for your connection to distinguish it later. 3. If prompted, choose to make this connection [shared or private](https://docs.supermetrics.com/docs/about-shared-and-private-connections). 4. Click **Start**. 5. In your data destination, select the data to be fetched based on the created or updated date. See detailed instructions on [how to connect to a data source from the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-connect-to-data-sources-from-supermetrics-hub). You can also connect to Wix Commerce from these destinations: - Google Sheets: [How to connect to a Supermetrics data source in Google Sheets](https://docs.supermetrics.com/docs/how-to-connect-to-a-supermetrics-data-source-in-google-sheets) - Data Studio: [How to connect data sources to Data Studio](/v1/docs/how-to-connect-data-sources-to-data-studio) - Excel: [How to connect data sources to Excel with Supermetrics](https://docs.supermetrics.com/docs/how-to-connect-data-sources-to-excel-with-supermetrics) - Power BI: [How to create your first Supermetrics query for Power BI](https://docs.supermetrics.com/docs/how-to-create-your-first-supermetrics-query-for-power-bi) - The Supermetrics API: [How to use the Query Manager](https://docs.supermetrics.com/docs/how-to-use-the-query-manager) - Data warehouse and cloud storage (Hub): [How to create a transfer](https://docs.supermetrics.com/docs/how-to-create-a-transfer) - BigQuery (marketplace): [How to create a BigQuery (marketplace) transfer](https://docs.supermetrics.com/v1/docs/how-to-create-a-bigquery-marketplace-transfer) ## More resources - [How to reauthenticate a data source connection](/v1/docs/how-to-reauthenticate-a-data-source-connection) - [How to manage data source connections on the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-manage-data-source-connections-on-supermetrics-hub)
