--- title: "Tripadvisor Reviews connection guide" slug: "tripadvisor-reviews-connection-guide" description: "Connect your Tripadvisor Reviews data to Supermetrics easily with our guide on permissions, location IDs, and query types for seamless reporting." tags: ["Brand reputation"] updated: 2026-11-05T07:51:59Z published: 2026-11-05T07:51:59Z canonical: "docs.supermetrics.com/tripadvisor-reviews-connection-guide" --- > ## Documentation Index > Fetch the complete documentation index at: https://docs.supermetrics.com/llms.txt > Use this file to discover all available pages before exploring further. # Tripadvisor Reviews connection guide This guide contains all permissions and requirements for connecting your Tripadvisor Reviews data to Supermetrics. You can connect to data sources from the [Data sources page on the Supermetrics Hub](https://hub.supermetrics.com/token-management). On the Hub, you can also [share an authentication link](https://docs.supermetrics.com/v1/docs/how-to-connect-to-data-sources-from-supermetrics-hub#share-authentication-link) to connect to a data source you don't have direct access to. After you connect to the data source on the Hub, you can use the data source connection in [all available destinations](/docs/tripadvisor-reviews-connection-guide#connection-instructions). ## Required permissions You need a business' location ID before you can pull its review data from Tripadvisor Reviews. You can find any location ID by copying the 7-digit code that follows the `-d` in any business' Tripadvisor URL. For example, if a venue's URL ended with `/Restaurant_Review-g123456-d7891011-Reviews-Example_venue.html`, the location ID would be `7891011`. ## Query types If prompted, you need to select a query type to pull data. - **Reviews**: View up to 100 of the most recent reviews. ## Connection instructions When connecting to Tripadvisor Reviews, you need to provide the business' location IDs to query. 1. Select the Tripadvisor Reviews data source [on the Supermetrics Hub](https://hub.supermetrics.com/token-management) or in the data destination. 2. If prompted, choose to make this connection [shared or private](/v1/docs/about-shared-and-private-connections). 3. Click **Start**. 4. In your data destination, select a query type, if prompted, and enter the location ID to include in your reporting. See detailed instructions on [how to connect to a data source from the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-connect-to-data-sources-from-supermetrics-hub). You can also connect to Tripadvisor Reviews from these destinations: - **AI tools and dashboards:** - AI chats: [How to connect Supermetrics to AI tools](/v1/docs/how-to-connect-supermetrics-to-ai-tools) - Supermetrics Studio: [How to create dashboards in Supermetrics Studio](/v1/docs/how-to-create-dashboards-in-supermetrics-studio) - **Spreadsheet and data visualization tools:** - Google Sheets: [How to connect to a Supermetrics data source in Google Sheets](https://docs.supermetrics.com/docs/how-to-connect-to-a-supermetrics-data-source-in-google-sheets) - Data Studio: [How to connect data sources to Data Studio](/v1/docs/how-to-connect-data-sources-to-data-studio) - Excel: [How to connect data sources to Excel with Supermetrics](https://docs.supermetrics.com/docs/how-to-connect-data-sources-to-excel-with-supermetrics) - Power BI: [How to create your first Supermetrics query for Power BI](https://docs.supermetrics.com/docs/how-to-create-your-first-supermetrics-query-for-power-bi) - **Supermetrics API, data warehouses, and cloud storage:** - The Supermetrics API: [How to use the Query Manager](https://docs.supermetrics.com/docs/how-to-use-the-query-manager) - Data warehouse and cloud storage (Hub): [How to create a transfer](https://docs.supermetrics.com/docs/how-to-create-a-transfer) - BigQuery (marketplace): [How to create a BigQuery (marketplace) transfer](https://docs.supermetrics.com/v1/docs/how-to-create-a-bigquery-marketplace-transfer) ## More resources - [Tripadvisor Reviews metrics and dimensions](/v1/docs/tripadvisor-reviews-fields) - [How to reauthenticate a data source connection](/v1/docs/how-to-reauthenticate-a-data-source-connection) - [How to manage data source connections on the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-manage-data-source-connections-on-supermetrics-hub)
