--- title: "Tradedoubler connection guide" slug: "tradedoubler-connection-guide" description: "Connect your Tradedoubler data to Supermetrics with our guide. Learn about permissions, API clients, and query types for seamless data integration." updated: 2026-07-08T11:55:44Z published: 2026-07-08T11:55:44Z canonical: "docs.supermetrics.com/tradedoubler-connection-guide" --- > ## Documentation Index > Fetch the complete documentation index at: https://docs.supermetrics.com/llms.txt > Use this file to discover all available pages before exploring further. # Tradedoubler connection guide This guide contains all permissions and requirements for connecting your Tradedoubler data to Supermetrics. You can connect to data sources from the [Data sources page on the Supermetrics Hub](https://hub.supermetrics.com/token-management). On the Hub, you can also [share an authentication link](https://docs.supermetrics.com/v1/docs/how-to-connect-to-data-sources-from-supermetrics-hub#share-authentication-link) to connect to a data source you don't have direct access to. After you connect to the data source on the Hub, you can use the data source connection in [all available destinations](/docs/tradedoubler-connection-guide#connection-instructions). ## Required permissions To connect Supermetrics to your Tradedoubler account, you need to create an API client and client secret. Note that only account owners can generate new API clients in Tradedoubler. Please contact Tradedoubler if you're not sure who the account owner is. ### Create a Tradedoubler API client 1. Log in to the [Tradedoubler API Client UI](https://solutions.tradedoubler.com/tools/api-client). 2. Create a client which provides a client ID and client secret. Note that the client secret is only shown once. Copy the client secret and keep it safe. ## Query types Query types define what sort of metrics and dimensions are available. You need to select one of the following query types when pulling data: - **Program**: Get aggregate performance metrics, such as impressions and clicks, per affiliate program. - **Affiliate**: Get aggregate performance metrics, such as impressions and clicks, per affiliate affiliate site. - **Ad**: Get aggregate performance metrics, such as impressions and clicks, per individual ad. ## Connection instructions When connecting to Tradedoubler, you need to provide your Tradedoubler credentials. 1. Select the Tradedoubler data source [on the Supermetrics Hub](https://hub.supermetrics.com/token-management) or in the data destination. 2. Enter your Tradedoubler username, password, client ID, and client secret. 3. Give your account a name to recognize the login later if you have multiple logins. 4. If prompted, choose to make this connection [shared or private](/v1/docs/about-shared-and-private-connections). 5. Click **Start**. 6. In your data destination, select a query type when prompted. See detailed instructions on [how to connect to a data source from the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-connect-to-data-sources-from-supermetrics-hub). You can also connect to Tradedoubler from these destinations: - Google Sheets: [How to connect to a Supermetrics data source in Google Sheets](https://docs.supermetrics.com/docs/how-to-connect-to-a-supermetrics-data-source-in-google-sheets) - Data Studio: [How to connect data sources to Data Studio](/v1/docs/how-to-connect-data-sources-to-data-studio) - Excel: [How to connect data sources to Excel with Supermetrics](https://docs.supermetrics.com/docs/how-to-connect-data-sources-to-excel-with-supermetrics) - Power BI: [How to create your first Supermetrics query for Power BI](https://docs.supermetrics.com/docs/how-to-create-your-first-supermetrics-query-for-power-bi) - The Supermetrics API: [How to use the Query Manager](https://docs.supermetrics.com/docs/how-to-use-the-query-manager) - Data warehouse and cloud storage (Hub): [How to create a transfer](https://docs.supermetrics.com/docs/how-to-create-a-transfer) - BigQuery (marketplace): [How to create a BigQuery (marketplace) transfer](https://docs.supermetrics.com/v1/docs/how-to-create-a-bigquery-marketplace-transfer) ## More resources - [How to reauthenticate a data source connection](/v1/docs/how-to-reauthenticate-a-data-source-connection) - [How to manage data source connections on the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-manage-data-source-connections-on-supermetrics-hub)
