--- title: "Squarespace Commerce connection guide" slug: "squarespace-commerce-connection-guide" description: "Connect your Squarespace Commerce data to Supermetrics with our guide on API keys, permissions, and detailed connection instructions for seamless data access." updated: 2026-07-08T11:55:44Z published: 2026-07-08T11:55:44Z canonical: "docs.supermetrics.com/squarespace-commerce-connection-guide" --- > ## Documentation Index > Fetch the complete documentation index at: https://docs.supermetrics.com/llms.txt > Use this file to discover all available pages before exploring further. # Squarespace Commerce connection guide This guide contains all permissions and requirements for connecting your Squarespace Commerce data to Supermetrics. You can connect to data sources from the [Data sources page on the Supermetrics Hub](https://hub.supermetrics.com/token-management). On the Hub, you can also [share an authentication link](https://docs.supermetrics.com/v1/docs/how-to-connect-to-data-sources-from-supermetrics-hub#share-authentication-link) to connect to a data source you don't have direct access to. After you connect to the data source on the Hub, you can use the data source connection in [all available destinations](/docs/squarespace-commerce-connection-guide#connection-instructions). ## Required permissions You need an API key in order to connect to Squarespace Commerce. Follow these steps to generate an API key: 1. Log in to your [Squarespace](https://login.squarespace.com/) site. 2. In the left side navigation, click **Settings**. 3. Select **Developer Tools**. 4. Click **Developer API Keys**. 5. Click **GENERATE KEY**. 6. In the dialog, add a key name under "KEY NAME", and enable “Read only” permission on the following: Products, Orders, Profiles 7. Click **GENERATE KEY** in the top right of the dialog. 8. Record the generated key in a safe and secure place. For security reasons, this is the only time the API key is visible. API keys will never expire as long as the merchant site remains active. See [Squarespace's documentation for more information about connecting to Squarespace Commerce](https://developers.squarespace.com/commerce-apis/authentication-and-permissions). ## Query types If prompted, you need to select a query type to pull data. - **Orders**: Fetch detailed insights about your shop orders. ## Connection instructions When connecting to Squarespace Commerce, you need to provide your API credentials when prompted. 1. Select the Squarespace Commerce data source [on the Supermetrics Hub](https://hub.supermetrics.com/token-management) or in the data destination. 2. Insert the API key. 3. If prompted, choose to make this connection [shared or private](/v1/docs/about-shared-and-private-connections). 4. Click **Start**. 5. In your data destination, select whether you want to fetch data based on created or modified date. See detailed instructions on [how to connect to a data source from the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-connect-to-data-sources-from-supermetrics-hub). You can also connect to Squarespace Commerce from these destinations: - Google Sheets: [How to connect to a Supermetrics data source in Google Sheets](https://docs.supermetrics.com/docs/how-to-connect-to-a-supermetrics-data-source-in-google-sheets) - Data Studio: [How to connect data sources to Data Studio](/v1/docs/how-to-connect-data-sources-to-data-studio) - Excel: [How to connect data sources to Excel with Supermetrics](https://docs.supermetrics.com/docs/how-to-connect-data-sources-to-excel-with-supermetrics) - Power BI: [How to create your first Supermetrics query for Power BI](https://docs.supermetrics.com/docs/how-to-create-your-first-supermetrics-query-for-power-bi) - The Supermetrics API: [How to use the Query Manager](https://docs.supermetrics.com/docs/how-to-use-the-query-manager) - Data warehouse and cloud storage (Hub): [How to create a transfer](https://docs.supermetrics.com/docs/how-to-create-a-transfer) - BigQuery (marketplace): [How to create a BigQuery (marketplace) transfer](https://docs.supermetrics.com/v1/docs/how-to-create-a-bigquery-marketplace-transfer) ## More resources - [How to reauthenticate a data source connection](/v1/docs/how-to-reauthenticate-a-data-source-connection) - [How to manage data source connections on the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-manage-data-source-connections-on-supermetrics-hub)
