--- title: "Sprinklr connection guide" slug: "sprinklr-connection-guide" description: "Connect your Sprinklr data to Supermetrics with our guide on permissions, query types, and connection instructions for seamless data integration." updated: 2026-07-08T11:55:44Z published: 2026-07-08T11:55:44Z canonical: "docs.supermetrics.com/sprinklr-connection-guide" --- > ## Documentation Index > Fetch the complete documentation index at: https://docs.supermetrics.com/llms.txt > Use this file to discover all available pages before exploring further. # Sprinklr connection guide This guide contains all permissions and requirements for connecting your Sprinklr data to Supermetrics. You can connect to data sources from the [Data sources page on the Supermetrics Hub](https://hub.supermetrics.com/token-management). On the Hub, you can also [share an authentication link](https://docs.supermetrics.com/v1/docs/how-to-connect-to-data-sources-from-supermetrics-hub#share-authentication-link) to connect to a data source you don't have direct access to. After you connect to the data source on the Hub, you can use the data source connection in [all available destinations](/docs/sprinklr-connection-guide#connection-instructions). ## Required permissions To connect to Sprinklr, you need to create your own **OAuth Application** within the Sprinklr developer environment to obtain the required credentials. You’ll also need your specific **Environment Parameter**. You can find the instructions to extract Environment from Sprinklr’s UI [here](https://dev.sprinklr.com/oauth-2-0-for-customers) or reach out to your Sprinklr admin or customer success manager. You also need access to a Sprinklr user account with the following permissions: - Generate Token - Generate Widget API Payload See [Sprinklr’s documentation](https://www.sprinklr.com/help/articles/roles-and-permissions/manage-roles/6467a80f30f12540268fb658) for details on how to manage roles in Sprinklr. ## How to create an OAuth application and obtain your Environment Parameter 1. Please follow the steps in [Sprinklr’s documentation](https://dev.sprinklr.com/api-key-and-secret-generation). 2. In the **Register Application** form, please enter the following **Callback URL**: `https://supermetrics.com/login-complete` 3. Once the application has been created, save your **API Key (Client_ID)** and **API secret (client_secret)** in a secure location. Take note of your Environment Parameter, as it is required to authenticate the connector. > [!NOTE] > Note > > Only one token can exist per API key. If you have multiple stateless instances, you’ll need to generate a separate API key and token paid for each instance. This means that if you plan to use the connector in multiple destinations, you must create a separate API key for each one. Alternatively, you can use a shared connection if you prefer a single setup across destinations. ## Query types If prompted, you need to select a query type to pull data. - **Post performance:** Measures the performance of individual social media posts. ## Connection instructions When connecting to Sprinklr, you need to log in to Sprinklr and check the combination of workspaces that should have access to the token. 1. Select the Sprinklr data source [on the Supermetrics Hub](https://hub.supermetrics.com/token-management) or in the data destination. 2. Insert **Client ID** and **Client Secret** you obtained from your OAuth 2.0 Application, and select your **Environment (ENV)** from the dropdown list. 3. If prompted, choose to make this connection [shared or private](/v1/docs/about-shared-and-private-connections). 4. Click **Start**. a. A Sprinklr login window will appear. **Log in** to your Sprinklr account. b. **Authorize** the Superetrics application to access your data. 5. In your data destination, select the **account(s)** you want to pull data from. See detailed instructions on [how to connect to a data source from the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-connect-to-data-sources-from-supermetrics-hub). You can also connect to Sprinklr from these destinations: - Google Sheets: [How to connect to a Supermetrics data source in Google Sheets](https://docs.supermetrics.com/docs/how-to-connect-to-a-supermetrics-data-source-in-google-sheets) - Data Studio: [How to connect data sources to Data Studio](/v1/docs/how-to-connect-data-sources-to-data-studio) - Excel: [How to connect data sources to Excel with Supermetrics](https://docs.supermetrics.com/docs/how-to-connect-data-sources-to-excel-with-supermetrics) - Power BI: [How to create your first Supermetrics query for Power BI](https://docs.supermetrics.com/docs/how-to-create-your-first-supermetrics-query-for-power-bi) - The Supermetrics API: [How to use the Query Manager](https://docs.supermetrics.com/docs/how-to-use-the-query-manager) - Data warehouse and cloud storage (Hub): [How to create a transfer](https://docs.supermetrics.com/docs/how-to-create-a-transfer) - BigQuery (marketplace): [How to create a BigQuery (marketplace) transfer](https://docs.supermetrics.com/v1/docs/how-to-create-a-bigquery-marketplace-transfer) ## More resources - [How to reauthenticate a data source connection](/v1/docs/how-to-reauthenticate-a-data-source-connection) - [How to manage data source connections on the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-manage-data-source-connections-on-supermetrics-hub)
