--- title: "Snowflake (Legacy) connection guide" slug: "snowflake-legacy-connection-guide" description: "Connect your Snowflake data to Supermetrics with our guide on permissions, authentication methods, and connection instructions for optimal reporting." tags: ["Databases and data warehouses"] updated: 2026-07-08T11:55:44Z published: 2026-07-08T11:55:44Z canonical: "docs.supermetrics.com/snowflake-legacy-connection-guide" --- > ## Documentation Index > Fetch the complete documentation index at: https://docs.supermetrics.com/llms.txt > Use this file to discover all available pages before exploring further. # Snowflake (Legacy) connection guide This guide contains all permissions and requirements for connecting your Snowflake data to Supermetrics. > [!NOTE] > Note > > This guide is for the legacy version of the Snowflake connector. For the new Snowflake connector, see [Snowflake connection guide](/v1/docs/snowflake-connection-guide). > > We strongly recommend that all new and existing users migrate to the new connector, as it is our focus for future enhancements and development. You can connect to data sources from the [Data sources page on the Supermetrics Hub](https://hub.supermetrics.com/token-management). On the Hub, you can also [share an authentication link](https://docs.supermetrics.com/v1/docs/how-to-connect-to-data-sources-from-supermetrics-hub#share-authentication-link) to connect to a data source you don't have direct access to. After you connect to the data source on the Hub, you can use the data source connection in [all available destinations](/docs/snowflake-legacy-connection-guide#connection-instructions). ## Required permissions There are 2 ways to authenticate Snowflake: with OAuth, or with a username and password. Note that in 2025, [Snowflake will require moving to key-pair authentication](/v1/docs/snowflakes-mandatory-mfa-action-required-by-november-2025). Using OAuth meets the need for mandatory key-pair or multi-factor authentication. [To connect with OAuth](https://docs.snowflake.com/en/user-guide/oauth-intro.html), you need an account with the Account admin role, plus a client ID and client secret. ****How to create an OAuth client ID and client secret**** 1. Log in to Snowflake and click **SYSADMIN**. 2. Click **Change**, and select the ACCOUNTADMIN role. 3. Run the following 2 commands in a worksheet: - First command: `CREATE SECURITY INTEGRATION` `    "Supermetrics App" ` `    TYPE = OAUTH ` `    ENABLED = TRUE ` `    OAUTH_CLIENT = CUSTOM ` `    OAUTH_CLIENT_TYPE = 'CONFIDENTIAL' ` `   OAUTH_REDIRECT_URI = 'https://supermetrics.com/login-complete' ` `;` - Second command: `SELECT SYSTEM$SHOW_OAUTH_CLIENT_SECRETS('Supermetrics App');` 4. Click row 1 in the output. You'll find this at the bottom of the screen. 5. A popup will open with 3 key-value pairs in JSON format. 6. Copy the values after the keys `OAUTH_CLIENT_ID` and `OAUTH_CLIENT_SECRET`. These are your client ID and client secret — keep them safe. To connect with a username and password, you need a database username and secret key with username, password, hostname, warehouse name, database name, and database schema. ****How to find your hostname, database name, and database schema**** You can find your hostname in the URL when you're logged in to Snowflake. It should end in `snowflakecomputing.com.` The warehouse name, database name, and database schema can be found in Snowflake at the top right of the query editor. ## IP allowlisting To enable Supermetrics for Snowflake, your database needs to accept connections from the Supermetrics IP addresses. [See this article for the IP addresses you need to allowlist](/v1/docs/about-ip-address-allowlisting). ## Query types You need to select one of the following query types when pulling data: - **Database table-based report**: Select a table from a schema, and use the columns of that table as the fields in Data Studio. - Make sure to check the "Warehouse, database name, and schema are case sensitive" option on the Snowflake login screen to enable this report type to work properly. - Date control doesn't work with this report type. - If the account you're using has multiple roles and the default role doesn't give it the permissions it needs to retrieve the table list, you might encounter problems getting your full list of tables. Change the account's default role or create a new account with only one role to solve the issue. - **Database query report**: Build an SQL query and use it to create report fields. With the SQL query, combine data from several tables, including those that are in different schemas. - Use this SQL workaround to use Date Control with this report type: `select * from MARKETING.MIX_PBI.GOOGLEADS_AD` `where DATE >= '#start-date#'` `AND DATE <= '#end-date#'` Note that SQL comments and Snowflake functions aren't supported in SQL-based reports. ## Connection instructions When connecting to Snowflake, you need to log in to Snowflake. 1. Select the Snowflake data source [on the Supermetrics Hub](https://hub.supermetrics.com/token-management) or in the data destination. 2. If prompted, choose to make this connection [shared or private](/v1/docs/about-shared-and-private-connections). 3. Click **Start**. 4. Select an authentication method. 5. Enter your credentials and click **Start**. 6. Create an SQL query under Query SQL. See detailed instructions on [how to connect to a data source from the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-connect-to-data-sources-from-supermetrics-hub). You can also connect to Snowflake from these destinations: - Google Sheets: [How to connect to a Supermetrics data source in Google Sheets](https://docs.supermetrics.com/docs/how-to-connect-to-a-supermetrics-data-source-in-google-sheets) - Data Studio: [How to connect data sources to Data Studio](/v1/docs/how-to-connect-data-sources-to-data-studio) - Excel: [How to connect data sources to Excel with Supermetrics](https://docs.supermetrics.com/docs/how-to-connect-data-sources-to-excel-with-supermetrics) - Power BI: [How to create your first Supermetrics query for Power BI](https://docs.supermetrics.com/docs/how-to-create-your-first-supermetrics-query-for-power-bi) - Supermetrics APIs: [How to get started with the Supermetrics APIs](/v1-api/apidocs/get-started-with-supermetrics-api) — You can also [create Data API query URLs in Data Explorer](/v1/docs/how-to-use-data-explorer). ## More resources - [How to reauthenticate a data source connection](/v1/docs/how-to-reauthenticate-a-data-source-connection) - [How to manage data source connections on the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-manage-data-source-connections-on-supermetrics-hub)
