--- title: "Smarp connection guide" slug: "smarp-connection-guide" description: "Connect your Smarp data to Supermetrics with our guide. Learn about permissions, API keys, and query types for seamless data integration." tags: ["Social media"] updated: 2026-11-05T07:58:26Z published: 2026-11-05T07:58:26Z canonical: "docs.supermetrics.com/smarp-connection-guide" --- > ## Documentation Index > Fetch the complete documentation index at: https://docs.supermetrics.com/llms.txt > Use this file to discover all available pages before exploring further. # Smarp connection guide This guide contains all permissions and requirements for connecting your Smarp data to Supermetrics. You can connect to data sources from the [Data sources page on the Supermetrics Hub](https://hub.supermetrics.com/token-management). On the Hub, you can also [share an authentication link](https://docs.supermetrics.com/v1/docs/how-to-connect-to-data-sources-from-supermetrics-hub#share-authentication-link) to connect to a data source you don't have direct access to. After you connect to the data source on the Hub, you can use the data source connection in [all available destinations](/docs/smarp-connection-guide#connection-instructions). ## Required permissions To connect Supermetrics to Smarp, you need: - **A Smarp subdomain**. This is the subdomain from your URL. - This is found after the `https://` in your Smarp URL. For example, in the URL `https: //examplestore.smarpshare.com`, **examplestore** is the Smarp subdomain. - **An API key**. You'll find this in the Smarp dashboard — remember to keep it safe once you have it. Read the [Authentication section of Smarp's basic concepts documentation](https://smarp.github.io/v1/#section/Basic-concepts/Versioning) to learn more. - **An account name.** This is the name you choose for your login. We recommend using your account's name. ## Query types Query types define what sort of metrics and dimensions are available. To access most query types, you'll need the **Company Admin** role level. You need to select one of the following query types when pulling data: - **Clicks:** Returns all clicks based on the period in which clicks happened. - **Campaigns:** Returns campaigns for a specific company. - **Groups:** Returns all groups within the instance. - **Posts:** Returns posts based on the period in which posts were published. Posts that have been deleted or were published in private channels won't be returned. - **Shares:** Returns all shares based on the period in which the share was done. - **Teams:** Returns all teams in the instance. - **Users**: Returns users in the company. ## Connection instructions When connecting to Smarp, you need to give your Smarp subdomain and an API key. 1. Select the Smarp data source [on the Supermetrics Hub](https://hub.supermetrics.com/token-management) or in the data destination. 2. Enter your Smarp subdomain and API key. 3. Give your login a name to recognize the login later if you have multiple logins. 4. If prompted, choose to make this connection [shared or private](/v1/docs/about-shared-and-private-connections). 5. Click **Start**. 6. In your data destination, select the query type to use. See detailed instructions on [how to connect to a data source from the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-connect-to-data-sources-from-supermetrics-hub). You can also connect to Smarp from these destinations: - **AI tools and dashboards:** - AI chats: [How to connect Supermetrics to AI tools](/v1/docs/how-to-connect-supermetrics-to-ai-tools) - Supermetrics Studio: [How to create dashboards in Supermetrics Studio](/v1/docs/how-to-create-dashboards-in-supermetrics-studio) - **Spreadsheet and data visualization tools:** - Google Sheets: [How to connect to a Supermetrics data source in Google Sheets](https://docs.supermetrics.com/docs/how-to-connect-to-a-supermetrics-data-source-in-google-sheets) - Data Studio: [How to connect data sources to Data Studio](/v1/docs/how-to-connect-data-sources-to-data-studio) - Excel: [How to connect data sources to Excel with Supermetrics](https://docs.supermetrics.com/docs/how-to-connect-data-sources-to-excel-with-supermetrics) - Power BI: [How to create your first Supermetrics query for Power BI](https://docs.supermetrics.com/docs/how-to-create-your-first-supermetrics-query-for-power-bi) - **Supermetrics API, data warehouses, and cloud storage:** - The Supermetrics API: [How to use the Query Manager](https://docs.supermetrics.com/docs/how-to-use-the-query-manager) - Data warehouse and cloud storage (Hub): [How to create a transfer](https://docs.supermetrics.com/docs/how-to-create-a-transfer) - BigQuery (marketplace): [How to create a BigQuery (marketplace) transfer](https://docs.supermetrics.com/v1/docs/how-to-create-a-bigquery-marketplace-transfer) ## More resources - [Smarp metrics and dimensions](/v1/docs/smarp-fields) - [How to reauthenticate a data source connection](/v1/docs/how-to-reauthenticate-a-data-source-connection) - [How to manage data source connections on the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-manage-data-source-connections-on-supermetrics-hub)
