--- title: "Shopware connection guide" slug: "shopware-connection-guide" description: "Connect your Shopware data to Supermetrics with our guide on permissions, API credentials, and integration steps for seamless data access." updated: 2026-07-08T11:55:44Z published: 2026-07-08T11:55:44Z canonical: "docs.supermetrics.com/shopware-connection-guide" --- > ## Documentation Index > Fetch the complete documentation index at: https://docs.supermetrics.com/llms.txt > Use this file to discover all available pages before exploring further. # Shopware connection guide This guide contains all permissions and requirements for connecting your Shopware data to Supermetrics. You can connect to data sources from the [Data sources page on the Supermetrics Hub](https://hub.supermetrics.com/token-management). On the Hub, you can also [share an authentication link](https://docs.supermetrics.com/v1/docs/how-to-connect-to-data-sources-from-supermetrics-hub#share-authentication-link) to connect to a data source you don't have direct access to. After you connect to the data source on the Hub, you can use the data source connection in [all available destinations](/docs/shopware-connection-guide#connection-instructions). ## Required permissions You need an **Access Key ID** and **Secure Access Key,** and your **store base URL** to connect to Shopware. The Access Key ID and Secure Access Key need to have at least **read** **level permission**s to Catalogues, Content, Customers, Orders, and Other (Sales Channels). If you’re unable to create a new key or find your store base URL, reach out to your store admin. ### How to find your credentials 1. Log in to your Shopware Admin panel. 2. Navigate to **Settings** → **System** → **Integrations**. 3. Click **Add Integration**. 4. Copy the Access Key ID and Secure Access Key 5. Your Base URL is your Shopware store URL (https://your-shop.example.com) ## Query types Query types define what sort of metrics and dimensions are available. You need to select one of the following query types when pulling data: - **Orders** - **Order items** ## Connection instructions When connecting to Shopware, you need to provide your API credentials and store base URL. 1. Select the Shopware data source [on the Supermetrics Hub](https://hub.supermetrics.com/token-management) or in the data destination. 2. Insert connection name, base URL, access key ID, and secure access key. 3. If prompted, choose to make this connection [shared or private](/v1/docs/about-shared-and-private-connections). 4. Click **Start**. 5. In your data destination, select whether to query data based on created or updated date. See detailed instructions on [how to connect to a data source from the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-connect-to-data-sources-from-supermetrics-hub). You can also connect to Shopware from these destinations: - Google Sheets: [How to connect to a Supermetrics data source in Google Sheets](https://docs.supermetrics.com/docs/how-to-connect-to-a-supermetrics-data-source-in-google-sheets) - Data Studio: [How to connect data sources to Data Studio](/v1/docs/how-to-connect-data-sources-to-data-studio) - Excel: [How to connect data sources to Excel with Supermetrics](https://docs.supermetrics.com/docs/how-to-connect-data-sources-to-excel-with-supermetrics) - Power BI: [How to create your first Supermetrics query for Power BI](https://docs.supermetrics.com/docs/how-to-create-your-first-supermetrics-query-for-power-bi) - The Supermetrics API: [How to use the Query Manager](https://docs.supermetrics.com/docs/how-to-use-the-query-manager) - Data warehouse and cloud storage (Hub): [How to create a transfer](https://docs.supermetrics.com/docs/how-to-create-a-transfer) - BigQuery (marketplace): [How to create a BigQuery (marketplace) transfer](https://docs.supermetrics.com/v1/docs/how-to-create-a-bigquery-marketplace-transfer) ## More resources - [How to reauthenticate a data source connection](/v1/docs/how-to-reauthenticate-a-data-source-connection) - [How to manage data source connections on the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-manage-data-source-connections-on-supermetrics-hub)
