--- title: "Semrush Projects connection guide" slug: "semrush-projects-connection-guide" description: "Connect your Semrush Projects data to Supermetrics with our guide on permissions, API keys, and query types for seamless data integration." tags: ["SEO", "Search"] updated: 2026-11-05T07:51:59Z published: 2026-11-05T07:51:59Z canonical: "docs.supermetrics.com/semrush-projects-connection-guide" --- > ## Documentation Index > Fetch the complete documentation index at: https://docs.supermetrics.com/llms.txt > Use this file to discover all available pages before exploring further. # Semrush Projects connection guide This guide contains all permissions and requirements for connecting your Semrush Projects data to Supermetrics. You can connect to data sources from the [Data sources page on the Supermetrics Hub](https://hub.supermetrics.com/token-management). On the Hub, you can also [share an authentication link](https://docs.supermetrics.com/v1/docs/how-to-connect-to-data-sources-from-supermetrics-hub#share-authentication-link) to connect to a data source you don't have direct access to. After you connect to the data source on the Hub, you can use the data source connection in [all available destinations](/docs/semrush-projects-connection-guide#connection-instructions). ## Required permissions To connect Supermetrics to Semrush Projects, you need an API account, an [API key](https://www.semrush.com/kb/92-api-key), and a Semrush subscription for API request units. [Learn more about Semrush accounts and API request units](https://www.semrush.com/api-use/). [Each API call has a cost, and the cost of requests is measured in API units.](https://www.semrush.com/api-analytics/) Units are determined by the type of report or request retrieved from the Semrush API, and fetching historical data requires more units than live data. One US dollar is equal to approximately 20,000 API units. ## Query types Set up your Semrush Project queries using any of the query types described below. ****Reference list: Semrush Projects query types**** - Position tracking - Campaign dates - Organic overview - Organic positions report - Adwords positions report - Organic competitors discovery report - Adwords competitors discovery report - Organic visibility index report - Adwords visibility index report - Site audit - Get a list of a campaign's snapshots - Get text descriptions about issues - Get information about a campaign - Get information about a snapshot - Detailed report for an issue - Get page ID by an URL - Get information about a page - Get snapshots history ## Connection instructions When connecting to Semrush Projects, you need to provide your API key and select the project to use when prompted. 1. Select the Semrush Projects data source [on the Supermetrics Hub](https://hub.supermetrics.com/token-management) or in the data destination. 2. Enter your API key. 3. If prompted, choose to make this connection [shared or private](/v1/docs/about-shared-and-private-connections). 4. Click **Start**. 5. In your data destination, select a project to include in your report and a query type. See detailed instructions on [how to connect to a data source from the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-connect-to-data-sources-from-supermetrics-hub). You can also connect to Semrush Projects from these destinations: - **AI tools and dashboards:** - Supermetrics Studio: [How to create dashboards in Supermetrics Studio](/v1/docs/how-to-create-dashboards-in-supermetrics-studio) - **Spreadsheet and data visualization tools:** - Google Sheets: [How to connect to a Supermetrics data source in Google Sheets](https://docs.supermetrics.com/docs/how-to-connect-to-a-supermetrics-data-source-in-google-sheets) - Data Studio: [How to connect data sources to Data Studio](/v1/docs/how-to-connect-data-sources-to-data-studio) - Power BI: [How to create your first Supermetrics query for Power BI](https://docs.supermetrics.com/docs/how-to-create-your-first-supermetrics-query-for-power-bi) - **Supermetrics API, data warehouses, and cloud storage:** - The Supermetrics API: [How to use the Query Manager](https://docs.supermetrics.com/docs/how-to-use-the-query-manager) - Data warehouse and cloud storage (Hub): [How to create a transfer](https://docs.supermetrics.com/docs/how-to-create-a-transfer) - BigQuery (marketplace): [How to create a BigQuery (marketplace) transfer](https://docs.supermetrics.com/v1/docs/how-to-create-a-bigquery-marketplace-transfer) ## More resources - [Semrush Projects metrics and dimensions](/v1/docs/semrush-projects-fields) - [How to reauthenticate a data source connection](/v1/docs/how-to-reauthenticate-a-data-source-connection) - [How to manage data source connections on the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-manage-data-source-connections-on-supermetrics-hub)
