--- title: "Semrush Analytics connection guide" slug: "semrush-analytics-connection-guide" description: "Connect your Semrush Analytics data to Supermetrics and bring SEO metrics like keyword rankings, organic traffic, and backlink data into your reporting tools." tags: ["Analytics", "SEO"] updated: 2026-07-08T11:55:44Z published: 2026-07-08T11:55:44Z canonical: "docs.supermetrics.com/semrush-analytics-connection-guide" --- > ## Documentation Index > Fetch the complete documentation index at: https://docs.supermetrics.com/llms.txt > Use this file to discover all available pages before exploring further. # Semrush Analytics connection guide This guide contains all permissions and requirements for connecting your Semrush Analytics data to Supermetrics. You can connect to data sources from the [Data sources page on the Supermetrics Hub](https://hub.supermetrics.com/token-management). On the Hub, you can also [share an authentication link](https://docs.supermetrics.com/v1/docs/how-to-connect-to-data-sources-from-supermetrics-hub#share-authentication-link) to connect to a data source you don't have direct access to. After you connect to the data source on the Hub, you can use the data source connection in [all available destinations](/docs/semrush-analytics-connection-guide#connection-instructions). ## Required permissions To connect Supermetrics to Semrush Analytics, you will need a paid Semrush subscription. Note that each query made with Supermetrics will use up the subscription's Web Query allotment, which is defined by the type of subscription. ## Query types Semrush Analytics supports 5 main types of queries — Domain, Keyword, URLs, Display Ads, and Backlinks — for a total of 35 different query types. Our connector uses the same structure as the API reports with the same names, so you can use the [Semrush Analytics API documentation](https://www.semrush.com/api-documentation/) to explore the full range of reports and fields. See our [Semrush Analytics report building guide](/v1/docs/semrush-analytics-report-building-guide) for more information about query types for this connector. ## Connection instructions When connecting to Semrush Analytics you need to log in to Semrush and select the query type and enter the domains to query. 1. Select the Semrush Analytics data source [on the Supermetrics Hub](https://hub.supermetrics.com/token-management) or in the data destination. 2. If prompted, choose to make this connection [shared or private](/v1/docs/about-shared-and-private-connections). 3. Click **Start**. 4. Enter your Semrush Analytics email and password, and click **Log in**. 5. Click **Approve**. 6. In your data destination, select a query type and enter one or more domains, separating each one with a comma with no whitespace (,). See detailed instructions on [how to connect to a data source from the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-connect-to-data-sources-from-supermetrics-hub). You can also connect to Semrush Analytics from these destinations: - Google Sheets: [How to connect to a Supermetrics data source in Google Sheets](https://docs.supermetrics.com/docs/how-to-connect-to-a-supermetrics-data-source-in-google-sheets) - Data Studio: [How to connect data sources to Data Studio](/v1/docs/how-to-connect-data-sources-to-data-studio) - Excel: [How to connect data sources to Excel with Supermetrics](https://docs.supermetrics.com/docs/how-to-connect-data-sources-to-excel-with-supermetrics) - Power BI: [How to create your first Supermetrics query for Power BI](https://docs.supermetrics.com/docs/how-to-create-your-first-supermetrics-query-for-power-bi) - The Supermetrics API: [How to use the Query Manager](https://docs.supermetrics.com/docs/how-to-use-the-query-manager) - Data warehouse and cloud storage (Hub): [How to create a transfer](https://docs.supermetrics.com/docs/how-to-create-a-transfer) - BigQuery (marketplace): [How to create a BigQuery (marketplace) transfer](https://docs.supermetrics.com/v1/docs/how-to-create-a-bigquery-marketplace-transfer) ## More resources - [Semrush Analytics report building guide](/v1/docs/semrush-analytics-report-building-guide) - [How to reauthenticate a data source connection](/v1/docs/how-to-reauthenticate-a-data-source-connection) - [How to manage data source connections on the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-manage-data-source-connections-on-supermetrics-hub)
