--- title: "Quantcast connection guide" slug: "quantcast-connection-guide" description: "Connect your Quantcast data to Supermetrics with our guide. Learn about required permissions, API keys, and connection instructions for seamless integration." tags: ["Paid media"] updated: 2026-11-05T07:51:59Z published: 2026-11-05T07:51:59Z canonical: "docs.supermetrics.com/quantcast-connection-guide" --- > ## Documentation Index > Fetch the complete documentation index at: https://docs.supermetrics.com/llms.txt > Use this file to discover all available pages before exploring further. # Quantcast connection guide This guide contains all permissions and requirements for connecting your Quantcast data to Supermetrics. You can connect to data sources from the [Data sources page on the Supermetrics Hub](https://hub.supermetrics.com/token-management). On the Hub, you can also [share an authentication link](https://docs.supermetrics.com/v1/docs/how-to-connect-to-data-sources-from-supermetrics-hub#share-authentication-link) to connect to a data source you don't have direct access to. After you connect to the data source on the Hub, you can use the data source connection in [all available destinations](/docs/quantcast-connection-guide#connection-instructions). ## Required permissions To connect Supermetrics to Quantcast, you need: - A copy of your account ID - An API key - An API secret ****Get your account ID**** 1. [Log in to Quantcast](https://www.quantcast.com/user/login?qcRefer=https%3A//www.quantcast.com/search%3Fq%3Dasraco.com). 2. Click **Account list** in the top right. 3. Click **View all**. 4. Copy the account ID for the account you want to connect. ****Get your API key and API secret**** 1. [Log in to Quantcast](https://www.quantcast.com/user/login?qcRefer=https%3A//www.quantcast.com/search%3Fq%3Dasraco.com). 2. In the top right, click the **Profile icon**, and then **My profile**. 3. Navigate to the "API key" section, and click **Create API Key**. 4. Quantcast will show your API key and API secret once. Copy these — remember to keep them safe and secure. ## Query types If prompted, you need to select a query type to pull data. - **Campaigns**: Measure the performance of your advertising campaigns. ## Connection instructions When connecting to Quantcast, you need to provide your credentials. 1. Select the Quantcast data source [on the Supermetrics Hub](https://hub.supermetrics.com/token-management) or in the data destination. 2. Enter the Account ID for the account you want to connect. 3. Enter that account's API key and API secret. 4. Give your login a name. The name can be anything — its purpose is for you to recognize the login later in case you have multiple logins. 5. If prompted, choose to make this connection [shared or private](/v1/docs/about-shared-and-private-connections). 6. Click **Start**. 7. In your data destination, select the query type, if prompted. See detailed instructions on [how to connect to a data source from the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-connect-to-data-sources-from-supermetrics-hub). You can also connect to Quantcast from these destinations: - **AI tools and dashboards:** - AI chats: [How to connect Supermetrics to AI tools](/v1/docs/how-to-connect-supermetrics-to-ai-tools) - Supermetrics Studio: [How to create dashboards in Supermetrics Studio](/v1/docs/how-to-create-dashboards-in-supermetrics-studio) - **Spreadsheet and data visualization tools:** - Google Sheets: [How to connect to a Supermetrics data source in Google Sheets](https://docs.supermetrics.com/docs/how-to-connect-to-a-supermetrics-data-source-in-google-sheets) - Data Studio: [How to connect data sources to Data Studio](/v1/docs/how-to-connect-data-sources-to-data-studio) - Excel: [How to connect data sources to Excel with Supermetrics](https://docs.supermetrics.com/docs/how-to-connect-data-sources-to-excel-with-supermetrics) - Power BI: [How to create your first Supermetrics query for Power BI](https://docs.supermetrics.com/docs/how-to-create-your-first-supermetrics-query-for-power-bi) - **Supermetrics API, data warehouses, and cloud storage:** - Supermetrics APIs: [How to get started with the Supermetrics APIs](/v1-api/apidocs/get-started-with-supermetrics-api) — You can also [create Data API query URLs in Data Explorer](/v1/docs/how-to-use-data-explorer). - Data warehouse and cloud storage (Hub): [How to create a transfer](https://docs.supermetrics.com/docs/how-to-create-a-transfer) - BigQuery (marketplace): [How to create a BigQuery (marketplace) transfer](https://docs.supermetrics.com/v1/docs/how-to-create-a-bigquery-marketplace-transfer) ## More resources - [Quantcast metrics and dimensions](/v1/docs/quantcast-fields) - [How to reauthenticate a data source connection](/v1/docs/how-to-reauthenticate-a-data-source-connection) - [How to manage data source connections on the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-manage-data-source-connections-on-supermetrics-hub)
