--- title: "Power BI integration: Setup & troubleshooting | Supermetrics" slug: "power-bi" description: "Unlock the power of Supermetrics in Power BI with essential guides, report templates, and troubleshooting tips for seamless data management." updated: 2026-07-10T09:01:52Z published: 2026-07-10T09:02:21Z canonical: "docs.supermetrics.com/power-bi" --- > ## Documentation Index > Fetch the complete documentation index at: https://docs.supermetrics.com/llms.txt > Use this file to discover all available pages before exploring further. # Power BI This section of the knowledge base covers everything you need to know about using Supermetrics to power your data in Power BI. Use these articles as a reference when you're getting started with Supermetrics in Power BI, want to work smarter, or experience any issues with your reports. You'll learn, for example, [how to use our report templates](/v1/docs/how-to-use-supermetrics-report-templates-in-power-bi) and how to [set up scheduled refreshes for your data](/v1/docs/how-to-set-up-scheduled-refreshes-in-power-bi). ## Get started with Power BI Follow these steps to get started: 1. First, register a Supermetrics account by [logging in to the Supermetrics Hub with your Microsoft or Google account using this link](https://hub.supermetrics.com/#register). If you have a Supermetrics account already, simply log in to the Hub. 2. Now, you're ready to [create your first query](/v1/docs/how-to-create-your-first-supermetrics-query-for-power-bi) on the Supermetrics Hub! Your trial starts when you create your first query. Take a look at our [data source connection guides](/v1/docs/connect) for the details you need to connect. 3. Then, [launch the Supermetrics connector for Power BI](/v1/docs/how-to-launch-the-supermetrics-connector-in-power-bi). If you can't find the Supermetrics connector, [check that you're running the latest version of Power BI Desktop](/v1/docs/how-to-check-the-power-bi-version-in-use). 4. Finally, you can [load your data to Power BI](/v1/docs/how-to-load-your-data-to-power-bi). The following video highlights the main steps for getting started with Supermetrics for Power BI. [Embedded content](https://www.youtube.com/embed/Uu1R6arOro8?&wmode=opaque) ## Learn more Take a look at how to [set a schedule for data refreshes](/v1/docs/how-to-set-up-scheduled-refreshes-in-power-bi), and explore the articles on using Supermetrics for Power BI. To get the most out of your data sources, take a look at our [data source guides, including report building guides](/v1/docs/connect). ## Report templates We have a wide range of report templates available for Power BI. You can find all templates in our [template gallery](https://supermetrics.com/template-gallery). ## Troubleshooting In case something doesn't go as expected, take a look at our troubleshooting articles for Power BI. If you're having issues with a data source, check out the [reauthentication guide](/v1/docs/how-to-reauthenticate-a-data-source-connection) and [articles related to the data source](/v1/docs/connect). Contact [our support team](https://hub.supermetrics.com/support) if you can't find an answer to solve your issue. Happy reporting!
