--- title: "Piwik PRO connection guide" slug: "piwik-pro-connection-guide" description: "Connect your Piwik PRO data to Supermetrics with our guide. Learn about required permissions, credentials, and query types for seamless integration." updated: 2026-07-08T11:55:02Z published: 2026-07-08T11:55:02Z canonical: "docs.supermetrics.com/piwik-pro-connection-guide" --- > ## Documentation Index > Fetch the complete documentation index at: https://docs.supermetrics.com/llms.txt > Use this file to discover all available pages before exploring further. # Piwik PRO connection guide This guide contains all permissions and requirements for connecting your Piwik PRO data to Supermetrics. You can connect to data sources from the [Data sources page on the Supermetrics Hub](https://hub.supermetrics.com/token-management). On the Hub, you can also [share an authentication link](https://docs.supermetrics.com/v1/docs/how-to-connect-to-data-sources-from-supermetrics-hub#share-authentication-link) to connect to a data source you don't have direct access to. After you connect to the data source on the Hub, you can use the data source connection in [all available destinations](/docs/piwik-pro-connection-guide#connection-instructions). ## Required permissions To connect to Piwik PRO, you'll need copies of your account name, client ID, and client secret. ****Get your account name**** 1. Log in to your Piwik PRO dashboard. 2. Your account name is the first part of the URL you see in your browser's address bar. - For example, if your URL is `exampleABC.piwik.pro`, then your account name is `exampleABC`. ****Get your client ID and client secret**** 1. Log in to your Piwik PRO dashboard. 2. Click **Menu** in the top left. 3. Select **Profile** from the dropdown. 4. Select the **API Keys** tab on the left. 5. Click **Create key**. 6. Give your key a memorable name. 7. Copy the client ID and client secret. **Keep them in a secure, safe place.** ## Query types If prompted, you need to select a query type to pull data. - **Analytics**: Fetch website and product analytics data from Piwik PRO's Analytics product. ## Connection instructions When connecting to Piwik PRO, you need to provide your credentials and select the account to use. 1. Select the Piwik PRO data source [on the Supermetrics Hub](https://hub.supermetrics.com/token-management) or in the data destination. 2. Enter your account name, client ID, and client secret. 3. If prompted, choose to make this connection [shared or private](/v1/docs/about-shared-and-private-connections). 4. Click **Start**. 5. In your data destination, select the accounts to include in your reporting and a query type, if prompted. See detailed instructions on [how to connect to a data source from the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-connect-to-data-sources-from-supermetrics-hub). You can also connect to Piwik PRO from these destinations: - Google Sheets: [How to connect to a Supermetrics data source in Google Sheets](https://docs.supermetrics.com/docs/how-to-connect-to-a-supermetrics-data-source-in-google-sheets) - Data Studio: [How to connect data sources to Data Studio](/v1/docs/how-to-connect-data-sources-to-data-studio) - Excel: [How to connect data sources to Excel with Supermetrics](https://docs.supermetrics.com/docs/how-to-connect-data-sources-to-excel-with-supermetrics) - Power BI: [How to create your first Supermetrics query for Power BI](https://docs.supermetrics.com/docs/how-to-create-your-first-supermetrics-query-for-power-bi) - The Supermetrics API: [How to use the Query Manager](https://docs.supermetrics.com/docs/how-to-use-the-query-manager) - Data warehouse and cloud storage (Hub): [How to create a transfer](https://docs.supermetrics.com/docs/how-to-create-a-transfer) - BigQuery (marketplace): [How to create a BigQuery (marketplace) transfer](https://docs.supermetrics.com/v1/docs/how-to-create-a-bigquery-marketplace-transfer) ## More resources - [How to reauthenticate a data source connection](/v1/docs/how-to-reauthenticate-a-data-source-connection) - [How to manage data source connections on the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-manage-data-source-connections-on-supermetrics-hub)
