--- title: "Partnerize connection guide" slug: "partnerize-connection-guide" description: "Connect your Partnerize data to Supermetrics with our guide. Learn about permissions, API keys, and query types for effective data management." updated: 2026-07-08T11:55:02Z published: 2026-07-08T11:55:02Z canonical: "docs.supermetrics.com/partnerize-connection-guide" --- > ## Documentation Index > Fetch the complete documentation index at: https://docs.supermetrics.com/llms.txt > Use this file to discover all available pages before exploring further. # Partnerize connection guide This guide contains all permissions and requirements for connecting your Partnerize data to Supermetrics. You can connect to data sources from the [Data sources page on the Supermetrics Hub](https://hub.supermetrics.com/token-management). On the Hub, you can also [share an authentication link](https://docs.supermetrics.com/v1/docs/how-to-connect-to-data-sources-from-supermetrics-hub#share-authentication-link) to connect to a data source you don't have direct access to. After you connect to the data source on the Hub, you can use the data source connection in [all available destinations](/docs/partnerize-connection-guide#connection-instructions). ## Required permissions Before using the Partnerize connector, you need a copy of your Application Key and API Key. ****Get your application key and API key**** 1. Log in to your account on the [Partnerize console](https://console.partnerize.com/login/partnerize/en). 2. In the Partnerize console, click your account name in the top left. 3. From the drop-down list, select **Account settings**. 4. On the left hand side, click the eye icons next to **Application Key** and **API Key** to reveal them. 5. Copy the application key and API key to a safe place. ## Query types Query types define what sort of metrics and dimensions are available. Supermetrics supports 3 Partnerize report types to fetch performance data of your partnerships. You need to select one of the following query types when pulling data: - Impression report - Click report - Conversion report ## Connection instructions When connecting to Partnerize, you need to provide your application key and API key. 1. Select the Partnerize data source [on the Supermetrics Hub](https://hub.supermetrics.com/token-management) or in the data destination. 2. Enter your application key and API key. 3. Give your login a name to recognize the login later if you have multiple logins. 4. If prompted, choose to make this connection [shared or private](/v1/docs/about-shared-and-private-connections). 5. Click **Start**. 6. In your data destination, select the accounts to pull data from and a query type. See detailed instructions on [how to connect to a data source from the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-connect-to-data-sources-from-supermetrics-hub). You can also connect to Partnerize from these destinations: - Google Sheets: [How to connect to a Supermetrics data source in Google Sheets](https://docs.supermetrics.com/docs/how-to-connect-to-a-supermetrics-data-source-in-google-sheets) - Data Studio: [How to connect data sources to Data Studio](/v1/docs/how-to-connect-data-sources-to-data-studio) - Excel: [How to connect data sources to Excel with Supermetrics](https://docs.supermetrics.com/docs/how-to-connect-data-sources-to-excel-with-supermetrics) - Power BI: [How to create your first Supermetrics query for Power BI](https://docs.supermetrics.com/docs/how-to-create-your-first-supermetrics-query-for-power-bi) - The Supermetrics API: [How to use the Query Manager](https://docs.supermetrics.com/docs/how-to-use-the-query-manager) - Data warehouse and cloud storage (Hub): [How to create a transfer](https://docs.supermetrics.com/docs/how-to-create-a-transfer) - BigQuery (marketplace): [How to create a BigQuery (marketplace) transfer](https://docs.supermetrics.com/v1/docs/how-to-create-a-bigquery-marketplace-transfer) ## More resources - [How to reauthenticate a data source connection](/v1/docs/how-to-reauthenticate-a-data-source-connection) - [How to manage data source connections on the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-manage-data-source-connections-on-supermetrics-hub)
