--- title: "Outbrain DSP (Zemanta) connection guide" slug: "outbrain-dsp-zemanta-connection-guide" description: "Connect your Outbrain DSP data to Supermetrics with our guide. Learn about permissions, client ID, and query types for seamless data integration." tags: ["DSP", "Paid media"] updated: 2026-11-05T07:58:26Z published: 2026-11-05T07:58:26Z canonical: "docs.supermetrics.com/outbrain-dsp-zemanta-connection-guide" --- > ## Documentation Index > Fetch the complete documentation index at: https://docs.supermetrics.com/llms.txt > Use this file to discover all available pages before exploring further. # Outbrain DSP (Zemanta) connection guide This guide contains all permissions and requirements for connecting your Outbrain DSP (Zemanta) data to Supermetrics. You can connect to data sources from the [Data sources page on the Supermetrics Hub](https://hub.supermetrics.com/token-management). On the Hub, you can also [share an authentication link](https://docs.supermetrics.com/v1/docs/how-to-connect-to-data-sources-from-supermetrics-hub#share-authentication-link) to connect to a data source you don't have direct access to. After you connect to the data source on the Hub, you can use the data source connection in [all available destinations](/docs/outbrain-dsp-zemanta-connection-guide#connection-instructions). ## Required permissions To connect Supermetrics to your Outbrain DSP (Zemanta) account, you need to create a client ID and client secret. ****Create client ID and client secret**** 1. [Log in to Outbrain DSP (Zemanta) using this link](https://one.zemanta.com/o/applications/). 2. Click **New Application**. 3. Enter a name for the application, for example, “Supermetrics”. 4. Click **Save**. 5. Copy the client ID and client secret and store them in a secure place for later use. ## Query types If prompted, you need to select a query type to pull data. - **Performance**: Measure the performance of your campaigns in Outbrain DSP (Zemanta). ## Connection instructions When connecting to Outbrain DSP (Zemanta), you need to provide your client ID and client secret and select the accounts to pull data from. 1. Select the Outbrain DSP (Zemanta) data source [on the Supermetrics Hub](https://hub.supermetrics.com/token-management) or in the data destination. 2. Enter your client ID and client secret. 3. Give your login a name to recognize the login later if you have multiple logins. 4. If prompted, choose to make this connection [shared or private](/v1/docs/about-shared-and-private-connections). 5. Click **Start**. 6. In your data destination, select the accounts to use in your reporting and a query type to use, if prompted. See detailed instructions on [how to connect to a data source from the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-connect-to-data-sources-from-supermetrics-hub). You can also connect to Outbrain DSP (Zemanta) from these destinations: - **AI tools and dashboards:** - AI chats: [How to connect Supermetrics to AI tools](/v1/docs/how-to-connect-supermetrics-to-ai-tools) - Supermetrics Studio: [How to create dashboards in Supermetrics Studio](/v1/docs/how-to-create-dashboards-in-supermetrics-studio) - **Spreadsheet and data visualization tools:** - Google Sheets: [How to connect to a Supermetrics data source in Google Sheets](https://docs.supermetrics.com/docs/how-to-connect-to-a-supermetrics-data-source-in-google-sheets) - Data Studio: [How to connect data sources to Data Studio](/v1/docs/how-to-connect-data-sources-to-data-studio) - Excel: [How to connect data sources to Excel with Supermetrics](https://docs.supermetrics.com/docs/how-to-connect-data-sources-to-excel-with-supermetrics) - Power BI: [How to create your first Supermetrics query for Power BI](https://docs.supermetrics.com/docs/how-to-create-your-first-supermetrics-query-for-power-bi) - **Supermetrics API, data warehouses, and cloud storage:** - The Supermetrics API: [How to use the Query Manager](https://docs.supermetrics.com/docs/how-to-use-the-query-manager) - Data warehouse and cloud storage (Hub): [How to create a transfer](https://docs.supermetrics.com/docs/how-to-create-a-transfer) - BigQuery (marketplace): [How to create a BigQuery (marketplace) transfer](https://docs.supermetrics.com/v1/docs/how-to-create-a-bigquery-marketplace-transfer) ## More resources - [Outbrain DSP (Zemanta) metrics and dimensions](/v1/docs/outbrain-dsp-zemanta-fields) - [How to reauthenticate a data source connection](/v1/docs/how-to-reauthenticate-a-data-source-connection) - [How to manage data source connections on the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-manage-data-source-connections-on-supermetrics-hub)
