--- title: "Odoo CRM connection guide" slug: "odoo-crm-connection-guide" description: "Connect your Odoo CRM data to Supermetrics with our guide. Learn about API keys, permissions, and integration steps for seamless data access." tags: ["CRM and sales", "Analytics"] updated: 2026-11-05T07:58:26Z published: 2026-11-05T07:58:26Z canonical: "docs.supermetrics.com/odoo-crm-connection-guide" --- > ## Documentation Index > Fetch the complete documentation index at: https://docs.supermetrics.com/llms.txt > Use this file to discover all available pages before exploring further. # Odoo CRM connection guide This guide contains all permissions and requirements for connecting your Odoo CRM data to Supermetrics. You can connect to data sources from the [Data sources page on the Supermetrics Hub](https://hub.supermetrics.com/token-management). On the Hub, you can also [share an authentication link](https://docs.supermetrics.com/v1/docs/how-to-connect-to-data-sources-from-supermetrics-hub#share-authentication-link) to connect to a data source you don't have direct access to. After you connect to the data source on the Hub, you can use the data source connection in [all available destinations](/docs/odoo-crm-connection-guide#connection-instructions). ## Required permissions You will need an **API key** and your **database name** in order to connect to Odoo CRM. ### How to create an API key 1. Log in to your [Odoo account](https://www.odoo.com/my/databases). 2. Select your database and the **CRM** module. 3. In the top-right corner, click on your user profile picture and select **Preferences**. 4. Select the **Security** tab. 5. In the **API Keys** section, click **Add API key**. 6. Enter your password to confirm your identity. 7. Give a name to your key (for example, “Supermetrics”) and define how long the key will be valid. If the key expires, you will need to create a new one. 8. Click on **Generate key**. 9. The API key will now be shown once; copy it to a secure location for later use. Full instructions to create an API key are available in [Odoo’s documentation](https://www.odoo.com/documentation/master/developer/reference/external_rpc_api.html#api-keys). ### How to find your database name 1. Log in to your [Odoo account](https://www.odoo.com/my/databases). 2. The database name is visible on the left side. ## Query types If prompted, you need to select a query type to pull data. - **Leads**: Retrieve detailed insights about your Odoo leads data. ## Connection instructions When connecting to Odoo CRM, you need to provide your API key and database name. 1. Select the Odoo CRM data source [on the Supermetrics Hub](https://hub.supermetrics.com/token-management) or in the data destination. 2. Enter the API key and database name. 3. If prompted, choose to make this connection [shared or private](/v1/docs/about-shared-and-private-connections). 4. Click **Start**. 5. In your data destination, select the ad accounts to include in your reporting and a query type, if prompted. See detailed instructions on [how to connect to a data source from the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-connect-to-data-sources-from-supermetrics-hub). You can also connect to Odoo CRM from these destinations: - **AI tools and dashboards:** - AI chats: [How to connect Supermetrics to AI tools](/v1/docs/how-to-connect-supermetrics-to-ai-tools) - Supermetrics Studio: [How to create dashboards in Supermetrics Studio](/v1/docs/how-to-create-dashboards-in-supermetrics-studio) - **Spreadsheet and data visualization tools:** - Google Sheets: [How to connect to a Supermetrics data source in Google Sheets](https://docs.supermetrics.com/docs/how-to-connect-to-a-supermetrics-data-source-in-google-sheets) - Data Studio: [How to connect data sources to Data Studio](/v1/docs/how-to-connect-data-sources-to-data-studio) - Excel: [How to connect data sources to Excel with Supermetrics](https://docs.supermetrics.com/docs/how-to-connect-data-sources-to-excel-with-supermetrics) - Power BI: [How to create your first Supermetrics query for Power BI](https://docs.supermetrics.com/docs/how-to-create-your-first-supermetrics-query-for-power-bi) - **Supermetrics API, data warehouses, and cloud storage:** - The Supermetrics API: [How to use the Query Manager](https://docs.supermetrics.com/docs/how-to-use-the-query-manager) - Data warehouse and cloud storage (Hub): [How to create a transfer](https://docs.supermetrics.com/docs/how-to-create-a-transfer) - BigQuery (marketplace): [How to create a BigQuery (marketplace) transfer](https://docs.supermetrics.com/v1/docs/how-to-create-a-bigquery-marketplace-transfer) ## More resources - [Odoo CRM metrics and dimensions](/v1/docs/odoo-crm-fields) - [How to reauthenticate a data source connection](/v1/docs/how-to-reauthenticate-a-data-source-connection) - [How to manage data source connections on the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-manage-data-source-connections-on-supermetrics-hub)
