--- title: "Nexxen DSP connection guide" slug: "nexxen-dsp-connection-guide" description: "Connect your Nexxen DSP data to Supermetrics with our guide. Learn about permissions, credentials, and reporting API access for seamless integration." tags: ["DSP", "Paid media"] updated: 2026-11-05T07:17:25Z published: 2026-11-05T07:17:25Z canonical: "docs.supermetrics.com/nexxen-dsp-connection-guide" --- > ## Documentation Index > Fetch the complete documentation index at: https://docs.supermetrics.com/llms.txt > Use this file to discover all available pages before exploring further. # Nexxen DSP connection guide This guide contains all permissions and requirements for connecting your Nexxen DSP data to Supermetrics. You can connect to data sources from the [Data sources page on the Supermetrics Hub](https://hub.supermetrics.com/token-management). On the Hub, you can also [share an authentication link](https://docs.supermetrics.com/v1/docs/how-to-connect-to-data-sources-from-supermetrics-hub#share-authentication-link) to connect to a data source you don't have direct access to. After you connect to the data source on the Hub, you can use the data source connection in [all available destinations](/docs/nexxen-dsp-connection-guide#connection-instructions). ## Required permissions Before using the Nexxen DSP data source connector, you need your Nexxen DSP client ID and client secret, as well as appropriate permissions for data access on your account. Follow the [instructions in Nexxen DSP's API documentation to generate the credentials](https://www.postman.com/nexxen-api/nexxen/documentation/9md8q3a/nexxen-dsp-apis). To pull reporting data, you need to have access to Reporting API. ## Query types If prompted, you need to select a query type to pull data. - **Performance**: Build reports with your performance data ## Connection instructions When connecting to Nexxen DSP, you need to provide your credentials. 1. Select the Nexxen DSP data source [on the Supermetrics Hub](https://hub.supermetrics.com/token-management) or in the data destination. 2. Enter your client ID and client secret. 3. Give your login a name. The name can be anything — its purpose is for you to recognize the login later in case you have multiple logins. 4. If prompted, choose to make this connection [shared or private](/v1/docs/about-shared-and-private-connections). 5. Click **Start**. See detailed instructions on [how to connect to a data source from the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-connect-to-data-sources-from-supermetrics-hub). You can also connect to Nexxen DSP from these destinations: - **AI tools and dashboards:** - AI chats: [How to connect Supermetrics to AI tools](/v1/docs/how-to-connect-supermetrics-to-ai-tools) - Supermetrics Studio: [How to create dashboards in Supermetrics Studio](/v1/docs/how-to-create-dashboards-in-supermetrics-studio) - **Spreadsheet and data visualization tools:** - Google Sheets: [How to connect to a Supermetrics data source in Google Sheets](https://docs.supermetrics.com/docs/how-to-connect-to-a-supermetrics-data-source-in-google-sheets) - Data Studio: [How to connect data sources to Data Studio](/v1/docs/how-to-connect-data-sources-to-data-studio) - Excel: [How to connect data sources to Excel with Supermetrics](https://docs.supermetrics.com/docs/how-to-connect-data-sources-to-excel-with-supermetrics) - Power BI: [How to create your first Supermetrics query for Power BI](https://docs.supermetrics.com/docs/how-to-create-your-first-supermetrics-query-for-power-bi) - **Supermetrics API, data warehouses, and cloud storage:** - The Supermetrics API: [How to use the Query Manager](https://docs.supermetrics.com/docs/how-to-use-the-query-manager) - Data warehouse and cloud storage (Hub): [How to create a transfer](https://docs.supermetrics.com/docs/how-to-create-a-transfer) - BigQuery (marketplace): [How to create a BigQuery (marketplace) transfer](https://docs.supermetrics.com/v1/docs/how-to-create-a-bigquery-marketplace-transfer) ## More resources - [Nexxen DSP metrics and dimensions](/v1/docs/nexxen-dsp-fields) - [How to reauthenticate a data source connection](/v1/docs/how-to-reauthenticate-a-data-source-connection) - [How to manage data source connections on the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-manage-data-source-connections-on-supermetrics-hub)
