title: "Liftoff connection guide"
slug: "lift-connection-guide"
description: "Connect LIFT to Supermetrics with our guide on permissions, authentication methods, and connection instructions."
updated: 2026-02-13T17:11:33Z
published: 2026-02-13T17:11:33Z
> ## Documentation Index
# Liftoff connection guide
This guide contains all permissions and requirements for connecting your Liftoff data to Supermetrics.
<meta charset="utf-8">
You can connect to data sources from the [Data sources page on the Supermetrics Hub](https://hub.supermetrics.com/token-management). On the Hub, you can also [share an authentication link](https://docs.supermetrics.com/v1/docs/how-to-connect-to-data-sources-from-supermetrics-hub#share-authentication-link) to connect to a data source you don't have direct access to.
After you connect to the data source on the Hub, you can use the data source connection in [all available destinations](/docs/lift-connection-guide#connection-instructions).
## Before you begin
Before using the Liftoff connector, you will need the API key and API Secret for your Liftoff account. Contact your Liftoff Account Manager to get your API key and API Secret emailed to you. Once you have received the key and secret, copy and store it securely.
## Query types
- **Campaign performance**: Measure the performance of your marketing campaigns in Liftoff.
## Connection instructions
When connecting to Liftoff, you need to enter your API key and API Secret and select the query type if prompted.
1. Select the Liftoff data source [on the Supermetrics Hub](https://hub.supermetrics.com/token-management) or in the data destination.
2. If prompted, choose to make this connection [shared or private](https://docs.supermetrics.com/docs/about-shared-and-private-connections).
3. Click **Start**.
4. In your data destination, select the organizations to include in your reporting and a query type, if prompted.
See detailed instructions on [how to connect to a data source from the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-connect-to-data-sources-from-supermetrics-hub).
You can also connect to Liftoff from these destinations:
- Google Sheets: [How to connect to a Supermetrics data source in Google Sheets](https://docs.supermetrics.com/docs/how-to-connect-to-a-supermetrics-data-source-in-google-sheets)
- Data Studio: [How to connect data sources to Data Studio](/v1/docs/how-to-connect-data-sources-to-data-studio)
- Excel: [How to connect data sources to Excel with Supermetrics](https://docs.supermetrics.com/docs/how-to-connect-data-sources-to-excel-with-supermetrics)
- Power BI: [How to create your first Supermetrics query for Power BI](https://docs.supermetrics.com/docs/how-to-create-your-first-supermetrics-query-for-power-bi)
- The Supermetrics API: [How to use the Query Manager](https://docs.supermetrics.com/docs/how-to-use-the-query-manager)
- Data warehouse and cloud storage (Hub): [How to create a transfer](https://docs.supermetrics.com/docs/how-to-create-a-transfer)
- BigQuery (marketplace): [How to create a BigQuery (marketplace) transfer](https://docs.supermetrics.com/v1/docs/how-to-create-a-bigquery-marketplace-transfer)
## More resources
- [How to reauthenticate a data source in Google Sheets, Data Studio, Excel, or Power BI](https://docs.supermetrics.com/docs/how-to-reauthenticate-a-data-source-connection-in-google-sheets-looker-studio-excel-power-bi-and-supermetrics-hub)
- [How to reauthenticate a data source in data warehouse, API, or cloud storage platform](https://docs.supermetrics.com/docs/how-to-reauthenticate-a-data-source-connection-in-data-warehouse-destinations-or-the-supermetrics-api)
- [How to manage data source connections on the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-manage-data-source-connections-on-supermetrics-hub)
