--- title: "Kwai Ads connection guide" slug: "kwai-ads-connection-guide" description: "Connect your Kwai Ads data to Supermetrics with our guide. Learn about permissions, credentials, and step-by-step connection instructions." updated: 2026-07-08T09:01:07Z published: 2026-07-08T09:01:07Z canonical: "docs.supermetrics.com/kwai-ads-connection-guide" --- > ## Documentation Index > Fetch the complete documentation index at: https://docs.supermetrics.com/llms.txt > Use this file to discover all available pages before exploring further. # Kwai Ads connection guide This guide contains all permissions and requirements for connecting your Kwai Ads data to Supermetrics. You can connect to data sources from the [Data sources page on the Supermetrics Hub](https://hub.supermetrics.com/token-management). On the Hub, you can also [share an authentication link](https://docs.supermetrics.com/v1/docs/how-to-connect-to-data-sources-from-supermetrics-hub#share-authentication-link) to connect to a data source you don't have direct access to. After you connect to the data source on the Hub, you can use the data source connection in [all available destinations](/docs/kwai-ads-connection-guide#connection-instructions). ## Required permissions Before using the Kwai Ads connector, reach out to Kwai to obtain the credentials you need to access the connector. Ask your contact at Kwai to create and share with you your client ID, client secret, and refresh token. Please note that each account has access to a specific set of Kwai datasets. Make sure that you request permissions from Kwai to all the relevant datasets you want to use in Supermetrics. See Kwai's [Supermetrics-Kwai integration manual](https://docs.qingque.cn/d/home/eZQA5tMfnGe-XsXlfryZcfG_e?identityId=1oE2MMiLl8m) for details about the connection steps. ## Connection instructions When connecting to Kwai Ads, you need to provide your credentials and select the accounts to use when prompted. 1. Select the Kwai Ads data source [on the Supermetrics Hub](https://hub.supermetrics.com/token-management) or in the data destination. 2. Enter the client ID, client secret, and refresh token. 3. Give a name for your account so that you can identify it later. 4. If prompted, choose to make this connection [shared or private](/v1/docs/about-shared-and-private-connections). 5. Click **Start**. 6. In your data destination, select the accounts to pull data from. See detailed instructions on [how to connect to a data source from the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-connect-to-data-sources-from-supermetrics-hub). You can also connect to Kwai Ads from these destinations: - Google Sheets: [How to connect to a Supermetrics data source in Google Sheets](https://docs.supermetrics.com/docs/how-to-connect-to-a-supermetrics-data-source-in-google-sheets) - Data Studio: [How to connect data sources to Data Studio](/v1/docs/how-to-connect-data-sources-to-data-studio) - Excel: [How to connect data sources to Excel with Supermetrics](https://docs.supermetrics.com/docs/how-to-connect-data-sources-to-excel-with-supermetrics) - Power BI: [How to create your first Supermetrics query for Power BI](https://docs.supermetrics.com/docs/how-to-create-your-first-supermetrics-query-for-power-bi) - The Supermetrics API: [How to use the Query Manager](https://docs.supermetrics.com/docs/how-to-use-the-query-manager) - Data warehouse and cloud storage (Hub): [How to create a transfer](https://docs.supermetrics.com/docs/how-to-create-a-transfer) - BigQuery (marketplace): [How to create a BigQuery (marketplace) transfer](https://docs.supermetrics.com/v1/docs/how-to-create-a-bigquery-marketplace-transfer) ## More resources - [How to reauthenticate a data source connection](/v1/docs/how-to-reauthenticate-a-data-source-connection) - [How to manage data source connections on the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-manage-data-source-connections-on-supermetrics-hub)
