--- title: "Klaviyo connection guide" slug: "klaviyo-connection-guide" description: "Connect your Klaviyo data to Supermetrics with our guide on permissions, API keys, and OAuth for seamless data integration across platforms." tags: ["Marketing automation", "Ecommerce"] updated: 2026-11-05T07:17:25Z published: 2026-11-05T07:17:25Z canonical: "docs.supermetrics.com/klaviyo-connection-guide" --- > ## Documentation Index > Fetch the complete documentation index at: https://docs.supermetrics.com/llms.txt > Use this file to discover all available pages before exploring further. # Klaviyo connection guide This guide contains all permissions and requirements for connecting your Klaviyo data to Supermetrics. You can connect to data sources from the [Data sources page on the Supermetrics Hub](https://hub.supermetrics.com/token-management). On the Hub, you can also [share an authentication link](https://docs.supermetrics.com/v1/docs/how-to-connect-to-data-sources-from-supermetrics-hub#share-authentication-link) to connect to a data source you don't have direct access to. After you connect to the data source on the Hub, you can use the data source connection in [all available destinations](/docs/klaviyo-connection-guide#connection-instructions). ## Required permissions To connect to Supermetrics, your Klaviyo account needs one of these user roles: - Admin - Owner - Manager [Learn more about user management and privileges in Klaviyo's documentation.](https://help.klaviyo.com/hc/en-us/articles/115005231648-User-Management-and-Privileges) ## Connection instructions When connecting to Klaviyo, you will need to log in with your Klaviyo user account and select the ad account to pull data from when prompted. 1. Select the Klaviyo data source [on the Supermetrics Hub](https://hub.supermetrics.com/token-management) or in the data destination. 2. If prompted, choose to make this connection [shared or private](/v1/docs/about-shared-and-private-connections). 3. Click **Start**. 4. Fill in the Email and Password fields with your Klaviyo account details. 5. Check the **I’m not a robot** box to pass the reCaptcha. 6. Click **Log in**. 7. There will be a warning that the app is not approved. This is okay — Supermetrics is in the process of getting our Klaviyo app approved with the Klaviyo team. Click Continue. 8. Review and approve the permissions for the app by clicking **Allow**. 9. In your data destination, select the accounts to include in your query. See detailed instructions on [how to connect to a data source from the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-connect-to-data-sources-from-supermetrics-hub). You can also connect to Klaviyo from these destinations: - **AI tools and dashboards:** - AI chats: [How to connect Supermetrics to AI tools](/v1/docs/how-to-connect-supermetrics-to-ai-tools) - Supermetrics Studio: [How to create dashboards in Supermetrics Studio](/v1/docs/how-to-create-dashboards-in-supermetrics-studio) - **Spreadsheet and data visualization tools:** - Google Sheets: [How to connect to a Supermetrics data source in Google Sheets](https://docs.supermetrics.com/docs/how-to-connect-to-a-supermetrics-data-source-in-google-sheets) - Data Studio: [How to connect data sources to Data Studio](/v1/docs/how-to-connect-data-sources-to-data-studio) - Excel: [How to connect data sources to Excel with Supermetrics](https://docs.supermetrics.com/docs/how-to-connect-data-sources-to-excel-with-supermetrics) - Power BI: [How to create your first Supermetrics query for Power BI](https://docs.supermetrics.com/docs/how-to-create-your-first-supermetrics-query-for-power-bi) - **Supermetrics API, data warehouses, and cloud storage:** - Supermetrics APIs: [How to get started with the Supermetrics APIs](/v1-api/apidocs/get-started-with-supermetrics-api) — You can also [create Data API query URLs in Data Explorer](/v1/docs/how-to-use-data-explorer). - Data warehouse and cloud storage (Hub): [How to create a transfer](https://docs.supermetrics.com/docs/how-to-create-a-transfer) - BigQuery (marketplace): [How to create a BigQuery (marketplace) transfer](https://docs.supermetrics.com/v1/docs/how-to-create-a-bigquery-marketplace-transfer) ## More resources - [Klaviyo metrics and dimensions](/v1/docs/klaviyo-fields) - [Klaviyo report building guide](/v1/docs/klaviyo-report-building-guide) - [How to optimize Klaviyo queries](/v1/docs/how-to-optimize-klaviyo-queries) - [How to reauthenticate a data source connection](/v1/docs/how-to-reauthenticate-a-data-source-connection) - [How to manage data source connections on the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-manage-data-source-connections-on-supermetrics-hub)
